Utah Evos
Old May 2, 2009 | 05:05 PM
  #24316
DIDYSIS's Avatar
anyone on here run an EGR block off plate??
Old May 2, 2009 | 05:13 PM
  #24317
DIDYSIS's Avatar
meth + boost= happy turbo
Old May 2, 2009 | 05:18 PM
  #24318
wesside's Avatar
Timmay that wouldn't cause your bov to stay open though
meth + boost= happy turbo & no worries about where the E85 station is at or draining the tank or what not to switch to 91 map haha
Old May 2, 2009 | 05:23 PM
  #24319
DIDYSIS's Avatar
Old May 2, 2009 | 05:25 PM
  #24320
DIDYSIS's Avatar
wow, sorry my computer wrote that 3 times
Old May 2, 2009 | 05:28 PM
  #24321
Timmay81's Avatar
it wouldnt cause it to stay full open but it would cause it to be in vac easier causing it to leak.
zip tied it up and hot damn it so much more responsive and boosting alot better
im gonna build a block plate this week infact
Old May 2, 2009 | 05:30 PM
  #24322
Timmay81's Avatar
Originally Posted by sikwititevo9
problem found problem fixed. now race wes.......
should be a good battle. we did a 3rd gear pull a few times and it was pretty even he did start pulling in the top on the 2nd race though
Old May 2, 2009 | 05:42 PM
  #24323
sikwititevo9's Avatar
thats good. i wish i could keep up with you guys
Old May 2, 2009 | 05:48 PM
  #24324
Timmay81's Avatar
e85 or water meth and you would be right with us.. a guy with a 9 in boise on e85 and stock turbo went exact same times i did
Old May 2, 2009 | 05:52 PM
  #24325
DIDYSIS's Avatar
If you feel the desire make me one too Ill make one sometime when I get to it.
Old May 2, 2009 | 05:55 PM
  #24326
what power range will i be at with the mods i listed earlier?
Old May 2, 2009 | 05:57 PM
  #24327
DIDYSIS's Avatar
9 with meth cams and about 27psi or more will make 400+ WHP, or just do 30PSI and its all good also. Been there done that. its a blast to go from 30-130mph
  #24328
wesside's Avatar
if you do then you should hook me up with your egr valve I get the p0401 egr valve insuffecient valve flow and I disabled the code...I think it's prob just dirty or **** for all I know it's stuck open / closed ?? I should pop it off one day but if you ditch yours then I could throw it on and re enabled the code to see if it gets thrown again
  #24329
DIDYSIS's Avatar
List mods again please and Ill give my guess.
Old May 2, 2009 | 05:59 PM
  #24330
DIDYSIS's Avatar
Id hook you up
