Utah Evos
Old Jun 3, 2009 | 06:13 PM
  #25501
gear head's Avatar
Originally Posted by MRevolutionIX
I saw this on ksl. It is the EJ257 though, not the EJ20.
http://www.ksl.com/index.php?nid=218...&cat=103&lpid=
I saw that too, but the EJ25 may blow his tranny with the extra power.
Old Jun 3, 2009 | 06:15 PM
  #25502
Ponce51's Avatar
Originally Posted by gear head
I'm just going to go with a new ACT sprung 6-puck with a Prolite flywheel.
ah, ya thats what i have as well, so u got the ACT pressure plate along with the disc and flywheel??
Old Jun 3, 2009 | 06:17 PM
  #25503
gear head's Avatar
Buying eveything together, either tomarrow or Friday.
Old Jun 3, 2009 | 06:19 PM
  #25504
Ponce51's Avatar
haha well thats gonna be fun for sure, if im not working or anything when u do it i'll be more than happy to help, just let me know
Old Jun 3, 2009 | 06:20 PM
  #25505
MRevolutionIX's Avatar
How far are you guys willing to go? And does the motor have to 100% working? I saw this also...
http://forums.nasioc.com/forums/show....php?t=1777837
Old Jun 3, 2009 | 06:25 PM
  #25506
wesside's Avatar
So did boost test and I'm leaking at the map where it was tapped Jason I'm gonna have to re tap the threads or something
Edit// it's not the threads although we did re tap them tonight...it's where the hole for map to seat in that leaks....need a plate to sit flush with spot on im and map to seat in that to make it work...I'm sure as hell not pulling off manifold well that way I wouldn't have to and no one would have to do any kind of crazy aluminum welding
Old Jun 3, 2009 | 06:42 PM
  #25507
DIDYSIS's Avatar
If anyone needs a clutch installed Ill do it at a good rate.
Old Jun 3, 2009 | 07:09 PM
  #25508
DIDYSIS's Avatar
JB WELD If you were around I would say I have some here.
Old Jun 3, 2009 | 07:41 PM
  #25509
mountainturbo's Avatar
Originally Posted by UT_Evo
Depends on how much the developers spent trying to make it realistic, the last one was good, don't get me wrong, but it wasn't as realistic as GT:Prologue, and GT5 will be even better. So Forzas going to have to step it up, or take a step in a different direction (as NFS, Burnout, etc have done).
I never had any problem with the realism in Forza 2, you turn off all the driving aids and I thought it was as good as GT. I put a ton of wheel time in with both though, I can see if you just picked one or the other up for a little bit it's different getting used to either.
I did always hate the fact in GT when I'd race my friends they'd use the damn rails on corners to turn And I thought Forza did a much better job with the sounds of the cars, but I love both of them so much
Have they actually announced a release date for GT5 yet? I hope it's soon, but they keep adding stuff like rally and nascar etc. etc. I don't care at all about the stupid nascar part, and the rally will be cool but I think the new DiRT game will probably be better for pure-rally driving, so I wish GT5 would just stick with what made the others so good and get the damn thing out already.
Old Jun 3, 2009 | 08:09 PM
  #25510
k20turbo's Avatar
Okay I don't see either of you guys on these list!!
My name is Todd I drive an 03 Evolution, I use to have a 600whp rsx I am sure I have met some of you here
Old Jun 3, 2009 | 08:18 PM
  #25511
DIDYSIS's Avatar
Welcome to the club, what turbo do you use to make 600 on an RSX??
Old Jun 3, 2009 | 08:29 PM
  #25512
k20turbo's Avatar
Thanks, it was a t3/t67. I have not decided on what I want to do with the evolution yet but I do know I want to make some power
Picture of my old rsx
Picture of my civic I parted out to build the evo
Picture of the evo
Old Jun 3, 2009 | 08:38 PM
  #25513
sikwititevo9's Avatar
so i checked my wastegate spring and its the large red one. which is only a 12 psi spring. so my question is for everyone why is it if i have a 12 psi spring and i havent even turned up my boost controller at all why is it that i am still boosting around 25lbs or so?
Old Jun 3, 2009 | 09:06 PM
  #25514
DIDYSIS's Avatar
How do you have the lines hooked up on the Gate Turbo etc??
Old Jun 3, 2009 | 09:08 PM
  #25515
DIDYSIS's Avatar
So your parting out the car, Seen it on KSL, thought about buying some parts really Nice setup. Just do some honda evo swap and wonderful evo.
Picture of the evo
