Utah Evos
Old Jun 6, 2009 | 08:16 AM
  #25621
k20turbo's Avatar
Originally Posted by DIDYSIS
I already want a 37R or 40R If I get another turbo I am thinking of going big. Even though the 35R should be plenty
4088R ftw
Old Jun 6, 2009 | 08:18 AM
  #25622
k20turbo's Avatar
Where are you guys putting your boost and wideband gauges?
Old Jun 6, 2009 | 08:23 AM
  #25623
Jorda420's Avatar
in the car JK
Old Jun 6, 2009 | 09:12 AM
  #25624
wesside's Avatar
Well I do install them at 100 foot pounds and never had then back out or any problems with them. Normal for all the main shops is between 100-90, Just did mine right now like 5 minuted ago. 100 is perfect.
Well like I said 100 is not what your supposed to tq them at and don't be surpirsed if other ppl start chiming in the same thing, shops go by instructions or all data and nothing anywhere or on forums tells you 100
Old Jun 6, 2009 | 09:18 AM
  #25625
wesside's Avatar
Originally Posted by ~BoOsTeR~
Put my Black ETS FMIC and EPM LICP on finally. Turbo winds up much easier. Is there a secret to getting the bumper back on without any gaps?
Removed worn upper bumper mesh, too - it was faded. Looks much better, especially w/the balck front mount. Removed the cooling panel on the hood too, looks sick, IMO.
Big cams, little turbo setup is finally taking flight, lol. All I have to do now is t belt, throw in cams, springs, retainers, valves, seats, guides, o2dump, URAD, 75mm TB, Intake Mani, Ex Mani, retune, you get the picture.
I'm leaning very heavily towards a ported BNIB Green or the Tomei right now. The Green would be much easier for me to get, but take longer - I could put it on my SEMA card. Tomei I'd have to come up with the cash, but it's cheaper and flows more and would get here sooner, I think.
What would you guys do?
I know what your aiming for in your setup and a 35r lag doesn't go in the mix
It would be very interesting to see what the tomei does if you went green route or a bbk or any other 9 based build at least you could send off your ix turbo to get some $$ knocked off..I say port whatever turbo you get on the hs a fp red would be sick of course
Old Jun 6, 2009 | 09:21 AM
  #25626
wesside's Avatar
Didysis your setup is good man don't go with different turbo hta35r on a 2.3 ftw
Steering column, gauge cluster or gauge pods I vote against the gauge pod
Old Jun 6, 2009 | 10:06 AM
  #25627
eficker's Avatar
Yeah, I've never heard of them going that tight. I think recommended is like 45. The ARP suggested is even lower than stock if you use their included moly grease.
I think the problem comes in when the iron block and alum head expand at different rates and there has to be a little room to give somewhere. I would fear that your head might distort over time with that much torque, but yours is a good test case, so let's see what happens and let us know.
Old Jun 6, 2009 | 10:16 AM
  #25628
k20turbo's Avatar
Yeah I really dont like the pillar pods... guess I will look into the steering column one
Old Jun 6, 2009 | 10:23 AM
  #25629
Jorda420's Avatar
im doing a 90 supercharged convertible 5.0 cobra with Nos he is going to fail
Old Jun 6, 2009 | 10:24 AM
  #25630
wesside's Avatar
I've had egt & boost on my steering column for a long time...I have a oil pressure that I've needed to get out of my dresser drawer for just as long I just don't know where to put it and eventually I'll go with the the 3 gauge cluster above the a/c but I want in cf
This isn't no pod just velcro
For a wideband it would be sick to do the lancer spot (same size as the mr/rs mitsu gauges...40-42mm?)
https://www.evolutionm.net/forums/ev...ul-gauges.html
Old Jun 6, 2009 | 10:58 AM
  #25631
TwoFour's Avatar
Hey Wes, put your rotors on and take some pics man!
Old Jun 6, 2009 | 11:10 AM
  #25632
DIDYSIS's Avatar
45 WHAT!!!!!!!!!!!! Normal for ARP is 80, Well you guys do what you want ill do as I want, thats the nice thing of doing it your self.
Old Jun 6, 2009 | 11:19 AM
  #25633
Evolution IVGSR's Avatar
Well you got the ported turbo still
Between my friend and I is what I said some stuff is in vegas storage unit.
I also have a evo 8 head, stock cams..my friend has a evo 8 block and head as well
haha Ya and I still need to take it apart
Want to See pics and on the Build thats sick what you are doing and as far as the turbo I would like to see someone with the Tomei since no one really has them. The Green everyone has around here JK but both are good turbos. I think Tomei > green right now.
FP RED or HTA35R or just stock 9 turbo My vote 35R
Bumper, just wiggle it and hold it tight while doing the bolts. They are already gaped a little, look at all the cars.
I say HTA35R man They are amazing on 2.3 I would also like to see what a FP Red would do on a 2.3 tho because thats what I wanted to try But if you need just a regular 35R I know someone that has one
haha HTA35R have made well into the 700's WHP Biggest I would go on a street car thats kind of a DD would be a 37R I think there is a HTA 37R too
SATURDAY I WIN, Putting the Evo together after finally getting parts
Dude we where up till like 2:20 last night playing COD how did you wake up so early I was up at 8:20 since my brother work me up
Ya man HYA all the Way +1 on my vote
Yep thats what I have too or in the Center where the Radio goes Not a fan of Pillar pods in Evos anyway
I have a Perrin one and I like it
Ya I have Boost and EGT too. I have my Wideban in a different place
Wes that Is a cool mod that guy did to his Stock gauge cluster I would like to do that too if I knew what I was doing
Old Jun 6, 2009 | 01:46 PM
  #25634
UT_Evo's Avatar
Stereo is sold, btw. And I lose!
Old Jun 6, 2009 | 01:48 PM
  #25635
Fairclough's Avatar
I hope you used L19's with that torque setting (they don't stretch) regular ARP head studs stretch. You are supposed to run the stud down hand tight the maybe a quarter turn past, maximum. Then install the washer and lube the nut, run the nut down, and torque to 90ft lbs.
