Utah Evos
Old Jun 6, 2009 | 02:08 PM
  #25636
TwoFour's Avatar
Fairclough- you get the stickers yeah?
Old Jun 6, 2009 | 02:19 PM
  #25637
Fairclough's Avatar
Yes! Thanks they look GREAT.
Old Jun 6, 2009 | 02:59 PM
  #25638
DIDYSIS's Avatar
They are just the normal ARP studs, I had a friend with a stretch gauge and we checked a set that had been torqued twice to 100 and they were still the same. So ya as i said before best bet is to do between 90 and 100
Originally Posted by Fairclough
I hope you used L19's with that torque setting (they don't stretch) regular ARP head studs stretch. You are supposed to run the stud down hand tight the maybe a quarter turn past, maximum. Then install the washer and lube the nut, run the nut down, and torque to 90ft lbs.
Old Jun 6, 2009 | 03:18 PM
  #25639
Aklittleman's Avatar
Anybody have a Defi Oil Pressure Gauge in red they wanna sell me?
Old Jun 6, 2009 | 04:45 PM
  #25640
eficker's Avatar
Originally Posted by DIDYSIS
45 WHAT!!!!!!!!!!!! Normal for ARP is 80, Well you guys do what you want ill do as I want, thats the nice thing of doing it your self.
I was thinking rod bolts, but still ARP is 71 with their moly:
Here
Everyone has their own way for sure...lol.
Stretch gauge is best, but I've never had any problems with ARP's recommendations, like you said, everyone has their own way.
Old Jun 6, 2009 | 05:04 PM
  #25641
~BoOsTeR~'s Avatar
Originally Posted by eficker
Hey guys. Just got an idea. If any of you want to get tuned, save a little coin and don't care about the dyno sheet, I can also road tune your car for $220. We'll install our own wb02 and get it handled.
Anyway, if anyone is interested, let me know.
Pm me here.
Yo fick, you gonna be up here for the summer? After I get my t belt done and the rest of ma shiz bolted in, I'll need a full on road or dyno tune.
This will be my mod list:
3" TBE (test pipe)
O2 dump
EPM LICP
Green or Tomei
3" FMIC w/Hard Pipes and ETS Intake (I'll need it scaled correctly)
WB02
1000cc's
Walboro 255
Kelford 272's
Supertech Valvetrain (Dual Springs, Ti Retainers, Seats, Bronze Guides, Seals, SS Nitrade Valves Stock Size)
Ported Stocker Intake Mani
Ported Stocker Exhaust Mani
75mm TB w 65mm adapter
3 port (Perrin EBCS - Interrupt mode, no pills)
JDM map (direct boost control - psi based)
2 byte logging (already done)
ARP Head Studs
Brand new pulleys, Kevlar Belts, etc
I think that's it - maybe I'll get an Aquamist kit from Wes...
Old Jun 6, 2009 | 05:31 PM
  #25642
~BoOsTeR~'s Avatar
I'm only up for a week (next week), but I may be back later in the summer. I'll post up here when I'm coming back up fo sho.
Do you do email - start up maps with build lists like that?
Old Jun 6, 2009 | 05:49 PM
  #25643
TwoFour's Avatar
perfect!
Old Jun 6, 2009 | 05:54 PM
  #25644
gear head's Avatar
WOW, quite the Controversy on Head studs
Just got done meeting with a Realtor....got a sweet home for sale in anyone is in the market for one
Old Jun 6, 2009 | 06:25 PM
  #25645
mountainturbo's Avatar
Me! lol Where? PM me some info.
Old Jun 6, 2009 | 07:56 PM
  #25646
sikwititevo9's Avatar
so i was getting on the freeway today and i decided to open her up on the on ramp since there wasnt anything in front of me. come to my surprise first and second were good then i got towards the top of third and had a nasty fuel cut. same thing in fourth gear.... so is it that i need bigger injectors or is my 255 pump not sufficient enough anymore? also would it matter where my wastegate is located on my manifold? my buddy told me he thinks i might get boost creep because of where it is on the manifold.... i will see if i can post a pic.
Old Jun 6, 2009 | 08:09 PM
  #25647
Old Jun 6, 2009 | 10:03 PM
  #25648
Jay644's Avatar
Originally Posted by k20turbo
Where are you guys putting your boost and wideband gauges?
On the subject of gauge placement, here's mine above the HVAC controls.
Old Jun 6, 2009 | 10:08 PM
  #25649
Jay644's Avatar
It might be that your getting fuel cut because you are hitting the max load cells on your ECU. My car would do that on cold nights with WOT in usually 3rd-4th-5th gears. Had my tune done and problem solved.
Old Jun 6, 2009 | 11:08 PM
  #25650
gear head's Avatar
You have pm
Yeah, lol. Didn't think there was so many ways to do it. I just do what the instructions tell me! lol
No doubt, they supply recomendations for a reason.
You are hitting load cut....raise the load limit in the "Boost Cut Load" table
