Utah Evos
Old Nov 22, 2005 | 08:58 AM
  #6091
silverofs's Avatar
Originally Posted by VIIImylunch
when you release the clutch and just barely engage the the gas pedal. The car shakes like crazy.
don't you have a twin disk??? if you do that's what is doing it it's the clutch disks chattering
Old Nov 22, 2005 | 09:36 AM
  #6092
typage's Avatar
My new evo is running terrible and I need it tuned. I'm in Idaho Falls. Who tunes your cars' down in Utah? I talked to Al with Dynoflash in CT and it would cost around $1500 to fly him out. Help!
Ty
Old Nov 22, 2005 | 09:40 AM
  #6093
bullfrg's Avatar
Ty,
We had Al come out in March and tuned a bunch of us in SLC. I believe there were some others trying to get him to come back to SLC, you may want to look for a post in the Dynoflash forum. If I had to do it again I would just ship my ecu to him and have him do a mail in flash. He has tuned enough cars he can get it 90% without even seeing your car and it saves having to deal with him in person.
Nice to see someone else from ID. I am in Twin Falls, do you ever do any autox?
Old Nov 22, 2005 | 09:48 AM
  #6094
typage's Avatar
Good advice. Is there anyone you recommend I could have look at my car to make sure the ECu needs to be reflashed? I'm not sure if that is the problem. It's running way too rich right now. Al thinks he already tuned the car with the previous owner and it should adjust just fine to the higher altitude.
Ty
Old Nov 22, 2005 | 09:51 AM
  #6095
VIIImylunch's Avatar
what mods are you running? The mail in flash didnt work out for me so well.
Old Nov 22, 2005 | 09:59 AM
  #6096
bullfrg's Avatar
Al will probably be the only guy that can tell if it was flashed previously. After my tune my car ran alot leaner then it had been so it is weird yours is running rich. Where did you get your car from? Have you made any changes? The nice thing about a flash is the factory ecu can still do its thing, so changes in altitude, weather, etc are adjusted by the ecu as always. I would find out from previous owner if Al flashed the car.
Old Nov 22, 2005 | 10:01 AM
  #6097
typage's Avatar
I'm having some internet issues but I'll post the link to Ebay that has pictures and a list of all mods. I bought it down in Orange County from Dinan Motors (Rudi)!
Old Nov 22, 2005 | 10:21 AM
  #6098
EvoMike's Avatar
Veteran: Air Force
Looking to send Al my ECU in a couple weeks. I am borrowing a data logger and will be running it on my trip to Pheonix. Looking to mail the data w/ the ecu so I can get a more accurate tune. Mine seems to be running rich compared to everyone elses i've seen around here even with the base flash. Plus i just installed cams!!
Old Nov 22, 2005 | 11:04 AM
  #6099
scott88vr6's Avatar
Mike when are you going to Phoenix? Al will be in Phoenix in a couple of weeks.
Old Nov 22, 2005 | 02:33 PM
  #6100
astrocreep96's Avatar
My Evo seems to run richer after the tune as well.
Old Nov 22, 2005 | 04:28 PM
  #6101
typage's Avatar
Stupid Norton antivirus is blocking me from all secure websites. Here's the link on the car I bought:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
It runs terrible and I'm not sure how to fix it here or in Utah. It ran great down in Orange County and now that it is up here it seems to be running way too much fuel!
Ty
Old Nov 22, 2005 | 04:42 PM
  #6102
silverofs's Avatar
Ty
well ty i would suggest one of two things option 1 send the ecu to al tell him all of those mods & tell him to flash it for 91 not 93 tun the boost down to 20psi.
secong buy a engine management system & have someone tune the car with that.
does it run bad all the time or just under full throttle conditions? if it's just under boost i bet the 22psi 93 octane flash isn't working so good with the 91 octane so you are detonating & pulling timing. if it runs ****ty all the time well there is too many things that could be wrong but if you explain what it's doing i can try to help
Old Nov 22, 2005 | 04:47 PM
  #6103
silverofs's Avatar
when you guys say "my car runs rich " is that because you see black smoke or you just have a feeling it's running rich??? most cars without a cat or a highflow cat will throw a good amount of black smoke out the back with the flash because he flashes it rich for the low octane to reduce knock.. you should have seen my car with my flash it would leave a smoke screen sometimes
Old Nov 22, 2005 | 04:59 PM
  #6104
typage's Avatar
It chugs, it detonates sometimes and you can now hear a knocking in the engine when it idles. When I say it chugs, I mean when I hit turbo, you can tell it struggles. It's trying to push out the gas or something. Strange, huh?
Old Nov 22, 2005 | 05:06 PM
  #6105
I have a feeling it's running rich because my mileage went down the ****ter. Seriously bad. I had thought that Evos were tuned fairly rich from the factory, and that more often than not, they would be leaned out compared to the factory map when tuned. So, at very least, I expected that the leaner map would compensate for the increased boost. But that doesn't seem to be the case.
Just a guess. I won't know until I have a wideband hooked up, which is to say that I'll probably never know since I don't have a wideband/money.
Edit - oh yeah, and on that original drive we went on way back last year (where we left from Applebee's, I think), I remember Ben's car puffing out big black clouds of smoke every time he got on it.
