Utah Evos
Old Nov 22, 2005 | 05:14 PM
  #6106
typage's Avatar
So does anyone down in SLC need Al to come out and we split the cost? I talked to him and he said he could be out next week. We just need about 10 guys to get the cost down to way way way cheap.
Ty
Old Nov 22, 2005 | 06:06 PM
  #6107
astrocreep96's Avatar
Ty
Custom tune by Al = $400
Used Utec = ~$500
I'd look into the Utec.
Old Nov 22, 2005 | 06:14 PM
  #6108
liberty2000rs's Avatar
I would second what Zach/astro just said. The utec is going to be a lot better choice then having Al tune the car.
Ty your car looks like it could have a lot of potential in the right hands. But from what you're explaining, i'd highly suggest you turn the boost down until you can get it straightend out. You may experience engine trouble otherwise. I imagine that you are experiencing lean missfire, not rich missfire. The combination of higher altitude (thinner air) and lower octane fuel would cause exactly that. Under acceleration when you're "in boost" it takes extremely rich conditions to see rich missfire, something around 9.8 to 10:1 air fuel ratios. On the other hand, if you are running lean, all it takes is mid to high 13's, which wouldn't be hard to see on a stock ecu, not to mention that the timing happy stock ecu isn't exactly prefered for turbos that will flow upwards of 50PPM.
Do you have a high Res camera?? Can you pull a spark plug and take a good photo?? If you can I can more than likely tell you what the car needs. A safe boost level would be anything under 18psi in the mean-time.
Old Nov 22, 2005 | 06:16 PM
  #6109
also, if you do buy a Utec, christian with modern garage can dyno tune the car. It will be tuned safely and professionally which from what i've heard is a little more than what you can expect from Al.
Old Nov 22, 2005 | 06:21 PM
  #6110
silverofs's Avatar
ha ha me & rob know what 9 to 1 a/f's look like don't we rob
Old Nov 22, 2005 | 06:59 PM
  #6111
VIIImylunch's Avatar
Go with the utec over the flash. There are a bunch for sale right now.
Old Nov 22, 2005 | 09:09 PM
  #6112
UT_Evo's Avatar
Christian is with COBB now Robby, but he still tunes em just the same.
Old Nov 22, 2005 | 09:23 PM
  #6113
So did he sell out??
Old Nov 22, 2005 | 09:53 PM
  #6114
UT_Evo's Avatar
sell out is definitly not what he did
Old Nov 22, 2005 | 11:33 PM
  #6115
bbbwrx's Avatar
Originally Posted by VIIImylunch
Did anyone else have the problem with your car shaking and rattling after cams were installed. How did you fix it?
Does the shaking go up with RPM? Cause if it is then if you took off you timing belt your balancing shafts are 180 degrees out of sync.
but if you did not take off the timing belt then i am out of ideas.
Ben
Old Nov 23, 2005 | 06:52 AM
  #6116
typage's Avatar
Where do you recommend buying the Utec at?
Ty
Old Nov 23, 2005 | 07:00 AM
  #6117
here is a link
https://www.evolutionm.net/forums/sh...d.php?t=169104
Old Nov 23, 2005 | 07:26 AM
  #6118
Hey do you know where I can find a Nano?? My wife wants one for X-mas, and I can't find them anywhere??
Old Nov 23, 2005 | 08:17 AM
  #6119
Let me check if I can get any.
Old Nov 23, 2005 | 09:48 AM
  #6120
typage's Avatar
Is Utec the only thing that you recommend for tuning?
Ty
