Utah Evos
Originally Posted by MSM_S2K
Thanks, look forward to seeing your post tune results. 193 seems low. What did the others get? My S2K was 209 before I had the motor built and the supercharger installed. Jake's Evo always felt consistently more powerful than the S2K until I had the supercharger installed. Based on how his Evo feels ... I always assumed the dyno numbers were closer to 240 or 250 to the wheels for the Evo. If it's only 193 ... I need to come with some new excuses for how he beat me at Spring Mountain.
No other Evos ran that day so I do not have anything to compare it to. You need to get your son's on there and see what it does, then I will have something to compare it to.
Now if only I cold take it to Modern anytime anyday and they could do it, too bad you have to reserve it like 4 months it advance cuz they're always to dang busy, but I'm gonna do the baseline for sure sometime soon. If you read about dynos on here though, you'll discover a lot of Evos run a lot of very varied numbers depending on a million things
Yes, I got a printout of my runs.
All dynos can be adjusted which in turn effects the #'s. Alot of it has to do with the operator. The guys I went down with went there because they trust Christian more then the local Idaho guys, I went because it is the only AWD dyno close to me. Were the numbers low maybe yes, maybe no, looks very similar to other runs on Mustang dynos so I am not worried. In reality it was just a baseline run to have an idea where the car was. Now I can see what each mod does and not guess whether I am making more power or not. The car feels fast and accelerates hard so I am not concerned with what #'s the dyno showed.
Originally Posted by silverofs
no offense but modern can adjust the settings on there dyno to read lower or higher than they really should!
I have called them recently, and Christian is usually available to do a baseline all the time. You just have to call about a week in advance.
We were going to try and organize an Evo Dyno day where we would get a discounted rate, but I just need to know who is actually interested. The prices would be from 90-100.00 and maybe more if you wanted the wideband.
I would probably be in. Last time it was $80 and then $25 for the wideband and if you were tuning there was an hourly charge, just fyi.
I would just need a new baseline with the new exhaust. Just got the downpipe and waiting to hear from Scott about a cat (reminder if you forgot).
Originally Posted by skiracer
A bit off topic, but i was in Alta/Snowbird last weekend and the snow quality up there absolutely rocks! Although it hasn't snowed in the past 3-4 days prior to my arrival, i still found many spots full of freshies in the glades and gulleys. You Utah peeps are absolutely spoiled up there and i'm totally jealous!
Yeah we are spoiled but you picked the wrong time to go. Cause we just go over 2 feet in the mountians.
Ben
