Utah Evos
Old Jan 22, 2006 | 10:19 PM
  #6766
sethrichmond's Avatar
Originally Posted by EvoMike
Is there anyone local with the 35R that will give me a ride!?
do you have a dollar?
Old Jan 23, 2006 | 05:08 AM
  #6767
scott88vr6's Avatar
Originally Posted by sethrichmond
you will not run low 11's on a 3071 at this altitude
stock or 35r
I bet topnotchevo could.....bwaaaaahahahahahahhahaha
Old Jan 23, 2006 | 06:58 AM
  #6768
VIIImylunch's Avatar
topnotchevo could do better than that, i heard he runs 8's.
Old Jan 23, 2006 | 08:27 AM
  #6769
EvoMike's Avatar
Veteran: Air Force
Yeah, I have a dollar!!
Old Jan 23, 2006 | 08:31 AM
  #6770
EvoMike's Avatar
Veteran: Air Force
Found out the the ring and pinion went out on the T.Case so now I get to buy a new one!! still going with the Stage 3 which has the a Quife LSD!! should have my car back together at the end of next week!!
Old Jan 23, 2006 | 09:16 AM
  #6771
scott88vr6's Avatar
thought you already had the t-case replaced???
Old Jan 23, 2006 | 09:18 AM
  #6772
tony gibson's Avatar
stock or 35r
x2...Maybe in Boise but not in Salt Lake....35R could get you there with enough tuning and driving.
Old Jan 23, 2006 | 09:44 AM
  #6773
silverofs's Avatar
in s.l.c i will be suprised if someone breaks into the 10's on the 35r i bet there will be some low 11's but i just don't know about 10's it would be cool if someone did it.
the 50 trim or 3071r is okay mike but it just isn't that much better than a stocker go to a 35r if your upgrading...
after liberty tuned my pump gas map on friday i want a pump gas rematch w/ seth i think i might just be a little suprising now we didn't touch the boost & i bet we made another 30-50whp it hauls *** now. (well for pump gas )
Old Jan 23, 2006 | 11:18 AM
  #6774
Yeh it would take a built motor and 35 psi to do it at that elevation with a 35r.
Old Jan 23, 2006 | 11:26 AM
  #6775
EvoMike's Avatar
Veteran: Air Force
No, I jumped the car last year by hitting a road gutter at 90mph which caused the bell housing to bend, the windsheild to break, front struts to blow and numerious other things. But the T.Case never was replaced.
Old Jan 23, 2006 | 12:01 PM
  #6776
what is your boost set at?
what did you do to the map?
what are your afr's on spool up and on peak boost (pump gas)
i remaped too. my afr's seem to like to change on me. i was in the freakin 10's
i pulled fuel out and now i'm in the low 11's again.
rematch on
Old Jan 23, 2006 | 12:02 PM
  #6777
do it fast...... do it furious
i'm rick james b!tch
Old Jan 23, 2006 | 12:18 PM
  #6778
scott88vr6's Avatar
F*uck ya couch!!!!!!!!!!!!!!!!!
I'm Rick James b!tch........show me ya *******
Old Jan 23, 2006 | 12:27 PM
  #6779
jid2's Avatar
THIS IS SETH'S BEST POST EVER.
Zach's info is classified, can't share super tuning secrets.
15:1, 40 psi I hear though.
Old Jan 23, 2006 | 01:38 PM
  #6780
silverofs's Avatar
hahahaaa i was in the low 10's on pump & about 19-20 psi
he helped me with the a/f's low 11's now & a few timing tweaks seth if you lose to me we have to switch motors so i can make that motor useful
my turbo>gt35r
evo mike how do you bend your bellhousing it's aluminum isn't it?? it would just crack if you hit it hard enough....
