Utah Evos
Old Dec 26, 2004 | 08:37 PM
  #826
MSM_S2K's Avatar
Originally Posted by UT_Evo
Santa Dollars? what santa dollars? did I miss something?
D'oh ... the one-sided bills that Santa gave you.
Old Dec 26, 2004 | 08:46 PM
  #827
UT_Evo's Avatar
Oh, you mean the ones that MOM accepted to buy the system for me?
Old Dec 27, 2004 | 08:21 AM
  #828
bullfrg's Avatar
Sorry I can't make it down. Post up the results when you get back.
Old Dec 27, 2004 | 11:53 AM
  #829
scott88vr6's Avatar
Here is mine.
Old Dec 27, 2004 | 11:59 AM
  #830
vtsnake's Avatar
scott, what do you have the mbc set at?
btw, its funny how you couldn't resist the urge after watching jakes car on the dyno. i talked to mike a few minutes ago and he told me.
Old Dec 27, 2004 | 12:08 PM
  #831
UT_Evo's Avatar
And here be mine
Old Dec 27, 2004 | 12:09 PM
  #832
vtsnake's Avatar
btw, i just noticed they showed your weight at 3100 lbs. is that correct? i think it's closer to 3300 in stock form. does that affect the dyno #'s at all?
Old Dec 27, 2004 | 12:10 PM
  #833
UT_Evo's Avatar
No, it's not correct, Christian says that they've weighed a bunch and just kinda picked an avg, and that it'd have to be a few hundred pounds off to make much of a difference, and to answer the #s question he said every 50lbs or so that it would be off might mean maybe 1 hp if that.
Old Dec 27, 2004 | 12:22 PM
  #834
liberty2000rs's Avatar
good numbers guys, interesting what a few bolt on mods do to performance. Has anyone seen other dyno charts with higher torque outputs than hp outputs?
Old Dec 27, 2004 | 12:31 PM
  #835
scott88vr6's Avatar
Originally Posted by liberty2000rs
good numbers guys, interesting what a few bolt on mods do to performance. Has anyone seen another dyno chart with higher torque outputs than hp outputs?
Mine shows 2 more torque than hp.
Ray my MBC is set to around 20.5 give or take a 1psi
Old Dec 27, 2004 | 12:43 PM
  #836
vtsnake's Avatar
thanks. you think i'd be safe around 24?
Old Dec 27, 2004 | 12:57 PM
  #837
scott88vr6's Avatar
With injectors and a fuel pump, my buddy is runnig 24 pounds, but with c-16
Old Dec 27, 2004 | 01:03 PM
  #838
scott88vr6's Avatar
I don't do well with peer pressure......i cave!
Old Dec 27, 2004 | 01:06 PM
  #839
vtsnake's Avatar
injectors and pump are going in tonight.
what's c-16?
Old Dec 27, 2004 | 01:18 PM
  #840
scott88vr6's Avatar
what's c-16?
race gas
