Utah Evos
Old Jul 30, 2007 | 09:50 PM
  #11446
silverofs's Avatar
i have seen & driven johns car many times & it is by far the cleanest evo out there!!!! i'm sure on a solid race gas tune that car could put down 420whp+ easy & would go 11's no problem or be a killer road race car....
Old Jul 30, 2007 | 10:56 PM
  #11447
evobeatsti's Avatar
Originally Posted by UT_Evo
2nd thru 5th might not break loose in a straight line when going is all they're using their friction for... But the famed Friction Circle is much more than that... You have traction used for braking, acceleration, and cornering. I think someone here can tell you about using all of the friction circle for cornering and then trying to use a lot of it for braking at the same time.
It comes back to my examples, I can hit the gas WOT before an Apex while a Corvette or other higher hp car has to wait untill after or even until they're going straight again to hit the gas fully.
good example as i experienced on saturday . my first day ever racing (at an autox) someone taught me the traction circle and understanding that concept is huge for a fast lap time. it is possible to have a fairly well balanced evo with a lot of hp. vesko's black evo must be making over 500whp but unlike most high hp evos he not only invested in power but also handling and braking. vesko found a good balance of power handling and braking for the car and that is very important, but the reliability issue comes into play as it seems that every time i see that black evo there are always problems with it while the white ca evo which has around 375whp doesnt experience any reliability issues that i know of but is only 1 or 2 seconds behind the black one lap time wise
Old Jul 30, 2007 | 10:58 PM
  #11448
Brembo350z's Avatar
Thanks Zach!
Old Jul 31, 2007 | 07:18 AM
  #11449
eficker's Avatar
Originally Posted by evobeatsti
is there any disadvantage to running a spacer on a street wheel? i have a 25mm spacer for my track wheels (17x9.5 nt03+m) and when i threw my street wheels back on (volk ce28 17x8.5 +30) i left the spacer on and it looks sick. will running with a spacer all the time cause extra stress or wear or have any negative side effects on daily driving?? thanks
There is a slight increase of stress on the wheel bearings, but not really enough to worry about, since you will need to change those every 15-20 hours of racing anyway. Unless you put 40k miles or more a year on your car, I wouldn't worry about it. And it does look sick!
Wrong. The black car has never seen more than 350hp on MMP. Ever. The reliability issues are not related to the hp (since its almost always on no boost), but to a faulty buscher ignition setup (not really buscher's fault, it was the prototype and I'm sure those bugs have been worked out).
The black car was like 4 seconds ahead of the white car and that was when he was just coasting around.
Old Jul 31, 2007 | 09:40 AM
  #11450
evobeatsti's Avatar
oh as you can see i really don't know much about vesko's cars. so if he is never running high boost and only set to around 350whp for miller why does the car have such a big turbo?? wouldnt it be more benificial to run a smaller turbo and have a way better powerband?? also the two guys with the white cars told me that they were running around 350-375 whp so what makes vesko's black car so much faster than the two white ones if they have the same whp and are on the same basic suspension and weight reduction level??
Old Jul 31, 2007 | 09:47 AM
  #11451
Biggie's Avatar
DRIVER... Vesko sold his soul to Satan for driving abilities.
Old Jul 31, 2007 | 01:52 PM
  #11452
eficker's Avatar
lol. He must have.
Old Jul 31, 2007 | 02:03 PM
  #11453
eficker's Avatar
Its setup that way because its what the previous owner wanted. Also, in case there is ever a need to run more boost, the option is there.
Old Jul 31, 2007 | 03:06 PM
  #11454
Biggie's Avatar
Originally Posted by eficker
lol. He must have.
Oh, I have proof!
And yes, Satan drives a Honda... But everyone knew that.
Old Jul 31, 2007 | 04:00 PM
  #11455
evobeatsti's Avatar
wow biggie you have way too much time on your hand lol
Old Jul 31, 2007 | 04:04 PM
  #11456
Biggie's Avatar
Oh, it would look a lot better than that if I spent more than 15 seconds on it...
Old Jul 31, 2007 | 07:19 PM
  #11457
05silevo's Avatar
My sychros are going out and I need to have my tranny rebuilt. What or who is the best way of going about this. Thanks
Old Aug 1, 2007 | 12:03 AM
  #11458
bbbwrx's Avatar
lol. He must have.
eficker and Biggie agree on something?? Vesko might lose his "powers" cause i think hell might have just froze over.
If you can send it to shep or TRE that is the way to go. If you need to get it done locally I don't know of anyone who specializes in them, Sadly Mitsu might be your best bet for rebuild. For removal and install Solid or Zach(silverofs) would be your best bet.
Old Aug 1, 2007 | 05:52 AM
  #11459
munoa13's Avatar
One of my problems with making so much power on the track is brakes. The more power you make the harder it is to slow down. Erich wrote this awesome race gas map the car made awesome power but requiered way different braking lines in order to keep the brakes together. The evos's imo don't need huge power because the grip they can produce. Lets just say that the only real threat to a properly driven street evo on the track are the race prepared cars. All the street cars like vipers, vetts and what ever else get real pissed when their super cars are punked by a 4dr "grandma car". I would like 420+whp to go around the track though guess it's time for a green .
Old Aug 1, 2007 | 05:54 AM
  #11460
munoa13's Avatar
Who is coming out to the Cobb Track Day?
