Question Works 76mm Downpipe, and Cat for IX
The site says this downpipe will fit IX, but they recommend the ceramic coating. Anyone one here have the ceramic coated DP and is it really worth the extra $100?
The works HFC should bolt up to any catback exhaust that connects to the stock cat right?
Maybe Works can answer this, I am planning to get the Works 76mm DP, Works HFC, and RMR exhaust. Will all these components fit okay?
Thanks
Thanks
Thanks
Thanks
The combination you're considering should be fine. You'll be ok with
any catback for that matter.
WORKS does recommend the thermal coating for all '05+ models. Not only does it help keep heat from radiating to the oil pan and other nearby components, it also helps prevent it from getting to the ACD. The stock DP has a heatshield around it for a reason and the thermal coating is there to mimic this.
Because all of our Exhale components are modular, you can replace them one piece at a time. This allows them to mate to the stock pieces as well as those that mount using OEM-style locations, flanges, etc...
Thanks for the replies. Will i get a CEL with the Works HFC? How can I fix it if I do?
will the o2 sensor for the 9 be in the same place if i get the hfc or a CEL will pop up
So what is the deal? I hear from everyone else that the larger the downpipe the better, then works says their 70mm downpipe is a little better than the 76mm.
I'm not sure which one would be better now.
The 70mm is for light/moderate modified. Basically intake exhaust flash and thats it. However, if you plan on modding your evo quite a bit, you need the extra flow for the 3 inch. Like they said, if you plan on doing o2, or ever upgrading your turbo, get the 76. Thats the one I got, put it on last week. Fit like a champ, very easy install.
Extensive testing has shown that a moderately modified Evo with this setup produces more power with a 70mm downpipe than a 76mm downpipe. This is due to minimizing abrupt gas expansion which cools the exhaust gases rapidly and creates undesirable turbulence.
^^I have the 70mm downpipe and intermediate pipe and I wish I would've purchased the 76mm intermediate pipe as then I could swap easily to an HFC. The stock cat is a restriction as well as a bit of a bottle neck from the 70mm DP. I did feel a mild gain and a quicker feeling spool up with my current set-up, but I'm really wanting an HFC.
