04-06 Ralliart Engine/Drivetrain (no forced induction)
Piggyback Maps
Old Aug 10, 2007 | 02:15 PM
  #151
DangerousDan's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=288700
for your wiring pleasure
Old Aug 10, 2007 | 02:32 PM
  #152
Originally Posted by Ralli///Art
I was playing with the software this morning and I clicked the "read data from ecu" button. When it showed the RRM setup, I pushed the pedal slowly up to redline and I noticed that the last case that was colored was in case 3.6v-7000rpm and the modified numbers began in case 2.8v-1000rpm. It literally touched 5-7 of the modified case numbers from row 6000rpm to 7000rpm. WTF?
this is the original RRM setup:
sistem settings: voltage, programable signal calibrator
engine settings: 4 stroke, 4 cylinders
output settings: pressure 30 to 0 psi /3 vds FS
everything else is stock (meaning no changes). My idle case is at row 1000rpm-1.6v or 1.7v and my redline case is at row 7000rpm-3.7v. Of course I don't have a wideband, buT I was thinking of copy/pasting qlitv's tune (the pr guy) but instead of leaving it as it is, start it in row 4000rpm-1.9v < that's aprox the mivec changeover and finishing it in row 7000rpm-3.7v.
the "cells" are meaningless at idle. there is no load on the engine, and you aren't seeing what the tracer would do when in third gear. your values will be slightly different in 4th compared to third, or 5th compared to 4th. that's why dyno pulls are done in 3rd or 4th gear, not 1st or 2nd.
the rows are "up to" the value stated, so that's why your mivec is in the 4000 row.
you need to do a ton of research before I would recommend playing with the values. any map you go to should be closer to stock than RRM's. RRM provides a base tune, and you need to have it tuned to your specific vehicle to maximize your results. to do that you need a wideband o2 sensor, or a trip to an eddy current dyno.
research. If you aren't careful you can really hurt your engine, or even destroy it, when messing with the fuel system. the closer to 10's the better, until you get a wideband. RRM's tunes have shown to be lean on some cars, there are many factors involved in tuning a car and they are in SoCal. If that doesn't mean anything to you, then you haven't done enough research yet. If you don't know what an eddy current dyno is, make sure you research that before you pay someone to tune your car.
Old Sep 26, 2007 | 08:30 PM
  #153
mitsuralli's Avatar
ok....i am new to tuning and have just purchased the piggy back for 89 octane from another member on here and also an aem wideband uego controller afr gauge http://www.strippermotorsports.com/a...FQlQWAodIDIvTA
bewtween these 2 items i should be able to properly view my afr vs rpm and adjust my map accordingly with the piggy back at each rpm......correct????
trying hard to soak it all up (and look b4 i ask) and ask the right questions
Old Sep 27, 2007 | 12:02 AM
  #154
stEVOx's Avatar
u can, but prolly better to get a wide band,
so u can see things like EGT so u know if something is up
Old Sep 27, 2007 | 03:53 AM
  #155
keep reading, but you are on the right track. once you get the wideband and piggy installed you will understand a little better, and I will be able to help you a little more. keep researching until then, the software and how to utilize the wideband with the piggyback should be your next line of research.
Old Sep 27, 2007 | 04:22 AM
  #156
stEVOx's Avatar
well thought i might as well ask here, but its prolly a stupid nub question but n e way
is it different from auto to manual(i have auto)
also i only do one tune and it applies to all gears correct?
TIA
Old Sep 27, 2007 | 08:12 AM
  #157
I am not sure what is different on the piggyback, but the manual and auto have different brains(ecu) one tune will apply to all gears.
Old Dec 3, 2007 | 09:22 PM
  #158
samj601's Avatar
i was talking to the guys at rrm today because i wanted to buy some parts. so far i have a catback, cai, pulley and going to put the piggyback back on. the piggyback of course comes pre-tuned for the basic mods which i have. my question was if i add the headers/dp and the im, would i need to get it retuned? to my surprise they said no and that it will "learn" by itself. is this right?
Old Dec 3, 2007 | 09:24 PM
  #159
migs647's Avatar
I don't know about "learn", but it does come pre-tuned for basic mods like that.
Old Dec 3, 2007 | 10:48 PM
  #160
Cow town racer's Avatar
I can't see this as the piggyback does not have capability to "learn", the ecu has this capability, but when you place a piggyback in the picture you are basically getting rid of the ecu's ability to learn and replacing it with your own designed set of signals so you can manipulate the numbers.
Now you won't have to have your piggyback retuned w/ those mods as they will not affect the A/F ratio enough to change anything dramatically, however, you will not get the full potential out of the mods if you do not tune it.
I could be completely wrong with what I have said, but from what I know of the ecu's learning, and the manipulation method of a piggyback I believe I am correct. Please correct me if I am wrong (which I'm sure DangerousDan will do).
Old Dec 4, 2007 | 04:11 AM
  #161
Myszkewicz's Avatar
The piggy doesn't interfere with the ECU's learning.
Old Dec 4, 2007 | 05:43 AM
  #162
what's the temperature difference between baltimore and RRM's hometown in socal? any time you have a temperature difference greater than a few degrees with a modified engine the OEM IAT fuel trims will be off.
everything in the ECU is preprogrammed. the sensors tell it what is coming in, the ECU relates what the sensors are telling it to a lookup map (potentially many maps) and does what it's programmed to do. no matter what changes, those maps stay the same. values that affect these maps, such as fuel trims from o2 sensors, change the whole equation not a cell in the map. this is why there is no need for a safe mode like every always claims is robbing their power; the ecu will function without certain sensors because there are default values. yeah, you have broken mode because the ECU can't function without certain sensors, but not safe mode.
with this little bit of information, what do you think the ECU is going to do when you change all kinds of restrictive parts to free flowing parts? the values from the sensors will change, and they should, but the lookup maps the ECU is referring to(which were designed around a completely stock engine, btw) have not changed. you may get the engine to trim in some fuel in closed loop operation, but you won't get any adjustment outside of a higher figure from the MAF sensor for open loop.
so, without getting into detail yes you will need to retune after modifying your engine, especially when changing your airflow. I can't believe RRM would tell you that headers, downpipe, and port and polished intake manifold would not require a retune, and can only guess that you didn't talk to Rob but rather one of his lackeys. I would suggest to anyone on the boards that if you call RRM that you speak to Rob or one of the other top people (I don't know anyone but Rob, because that's who I talk to) and nobody else. there has been too much misinformation coming from them lately, at least according to the people posting here.
Old Dec 4, 2007 | 11:30 AM
  #163
^^^^ that's what I was saying ... lol
Old Dec 4, 2007 | 11:52 AM
  #164
yeah, I just worded it different
Old Dec 4, 2007 | 12:25 PM
  #165
ROCK's Avatar
Remember the stock ECU still has some abilty to adjust so adding most mods other than pistons will be adjsuted for. You will be fine with the tune we give you really even if you add a cam.
ROAD/RACE
