04-06 Ralliart Engine/Drivetrain (no forced induction)
Piggyback Maps
Old Dec 5, 2007 | 08:39 AM
  #166
DangerousDan's Avatar
can you elaborate a little? what sensors (other than airflow meter) allow for an adjustment by the ECU for a cam, header/DP or P&P IM? seems like we are reaching here to me, I'd hate to put all that stuff in my car and find out it's super lean. remember, some of the people with one base tune or another of RRM's has come up lean with the recommended mods for that base tune. mods like those mentioned would almost definitely cause a lean burn when it's already kind of lean as it is.
I don't want to say your wrong, but you aren't giving us any reason aside from your word that we will "be fine." I've given some pretty sound advice in regards to how the ECU is supposed to work, at least according to all my research and limited experience with this car so far, and I don't think being fine and tuned properly are interchangeable. yeah, your engine probably won't blow up, but you damn sure aren't getting what you should out of the car. not even close; the temperature difference between summer and winter here leans me out quite a bit, that's not even close to safe if your AFR's are steady at 13.3 in the summer
please give us further detail.
Old Jan 25, 2008 | 09:21 AM
  #167
ill eagle's Avatar
im just wondering what type of piggy back is the most commonly used one.
Old Jan 25, 2008 | 09:23 AM
  #168
migs647's Avatar
I'm gonna go out on a limb and say RRM's piggy.
Old Jan 25, 2008 | 10:35 AM
  #169
for the RA or in general? for the RA by far the split second unit RRM sells. right now it is one of two piggyback units proven to tune fuel on the RA. the other is the AEM FIC which does not use the MAF circuit to control fuel.
Old Jan 28, 2008 | 11:29 AM
  #170
ROCK's Avatar
RRM piggy is the only pretuned unit however for any of the Lancers! They all come with software now but you do not need it unless you want to do a custom tune etc.... AGAIN software is included with all piggies now. Thanks Dan.
ROAD/RACE
Old Jan 28, 2008 | 03:27 PM
  #171
stEVOx's Avatar
^still didnt get mine after re-asking twice btw, but nvm, not gonna get it dynoed now, saving for 09 RA so stop posting here and start making parts for it :P
Old Mar 24, 2008 | 12:56 AM
  #172
Puddles's Avatar
new maps?
hey guys i just bought the v2 Piggy back and i was just wondering if anyone has any good maps out there. my mods are SRI, UDP, custom exhaust for the engine so far. i saw one of dans maps when he had similar mods done to his car and i am going to test that one out the second i get a cable. but if anyone has/had similar mods and has a really nice working map it would be great to see. working on getting a wideband soon so not to worry.
Old Mar 24, 2008 | 07:15 AM
  #173
ROCK's Avatar
BAse map should be fine but if you are going to custom tune make sure you get a Zeitronix ZT-2 or get on the dyno.
ROAD/RACE
Old Apr 3, 2008 | 09:13 AM
  #174
Lancerally_Mick's Avatar
Someone has a map for the mod I have ? (signature)
Old Apr 14, 2008 | 03:21 PM
  #175
hello ?
Old Apr 15, 2008 | 07:16 AM
  #176
you need to read. we aren't here to offer maps up any time someone asks. there is a lot more into a proper map than just picking one out. if you are looking for a base map the piggy comes with one; go to a tuner and have them make it yours
Old Apr 26, 2008 | 07:54 AM
  #177
I have the Split Second CD , I installed it just to see and there's a file. I open it and there's a chart fill with numbers.
Its probably a base map, but what does it do. I know I should go on a dyno to tune my car but I want do it myself and learn. Im not a mec but I love to do all by myself.
If you want you can PM me if someone want to help me a bit
Thank you
Old Apr 26, 2008 | 11:59 PM
  #178
Myszkewicz's Avatar
Sorry, but if you don't even understand how a fuel map works, this is a little beyond your abilities at the moment.
There are several good threads about piggyback maps, mostly either started by or filled with posts by DangerousDan, that go into greater detail about how to tune the piggy yourself.
Basically, if you don't want to dyno tune and pay someone to do it for you, you'll need a wideband O2 sensor and a laptop. Datalog a couple runs, make SMALL adjustments, and datalog more runs until you hit the AFR you were shooting for.
Old Apr 27, 2008 | 09:12 PM
  #179
ROCK's Avatar
YEA. Not always good to teach yourself how to tune. OUr piggys come pretuned. Stick with that until you do some wild mods. It will be hard to beat the base map we supply in most cases.
ROAD/RACE
Old Apr 30, 2008 | 03:11 PM
  #180
$MIVEC$'s Avatar
Originally Posted by DangerousDan
anything under 2.8volts is under 2000 rpms at WOT and should not be messed with unless you are tuning for a different fuel system because it affects idle. most of these changes will not affect your tune at all because the ECU only uses MAF readings in open loop conditions.
I would like to know how accurate is this info
