Shifter will "pop" out of 1st gear HELP!
wait, i'm confused... what it sounds like you're saying is while trying to shift into second the shifter seems to jump that direction anyhow. this is a bad thing how? i've experienced something similiar in both my evo and the lancer and always thought it was a good thing - a perfect shift. now if it's jumping out on it's own, that would be reason to worry.
Originally Posted by redlne8
When i accel. from a full stop not even WOT and go to shift into 2nd it sometimes feels like 1st gear is "spring loaded". The shifter almost pops out of first when I pull back into second. My 05` has 15,500 miles on it so it's like brand new. This has even happened at only 3k on the tach. Not quite sure if I should take it to the dealer or not. Can I get some advise, or anyone else run into this problem?
If the shifter is popping out randomly just while you're driving that's a bad thing. If you're starting to shift and the shifter feels like it's being sucked towards the next gear by some mystery force, that's nothing more than the synchros being perfectly aligned. It's a good thing!
