04-06 Ralliart Engine/Drivetrain (no forced induction)
Car loses power around 5,800rpms
Old Sep 5, 2011 | 05:59 PM
  #61
Ralliartize It's Avatar
OK I will do some more hunting and get back to you.
Dacib - reach out to souless, Mysc, SSP, or Otter in the mean time.
Old Sep 5, 2011 | 06:01 PM
  #62
dacib's Avatar
Thanx a lot!!!
Old Sep 5, 2011 | 07:17 PM
  #63
otter's Avatar
EvoM Administrator
Those of you having problems (I've honestly lost track of who has what problem) need to do some basic diagnostic work. First off, you need to know your fuel ratio, and running an aftermarket cam without a tune is not very smart. For an auto trans not shifting, you need to check out your vacuum system, as vacuum is a big part of what tells an auto trans when to shift.
The engine oil pressure has no relation to the fluid pressure in a transmission. They're two completely separate systems.
Old Sep 6, 2011 | 04:56 AM
  #64
dacib's Avatar
When I spoke with Ken at Delta he said the same thing that at WOT I don't have enough vacuum in the transmission. I visually checked all the vacuum lines and they look good.
I have contacted Hackish for the tune but he said to wait till he releases the software(still waiting). Ken mentioned that I can hook a vacuum canister but i don't know where since I don't see any vacuum lines going or coming from the transmission.
Old Sep 6, 2011 | 06:56 AM
  #65
I'll see if I can pull a diagram of the vaccum system.
Old Sep 6, 2011 | 08:47 AM
  #66
dacib's Avatar
I owe you my life...
Old Sep 6, 2011 | 09:03 AM
  #67
lanzerralliart's Avatar
EvoM Super Moderator
be careful he might take you up on that.....
Old Sep 7, 2011 | 10:00 AM
  #68
soulesswarrior's Avatar
Question did you have the transmission cooler on before the cam?
Old Sep 7, 2011 | 10:06 AM
  #69
otter's Avatar
EvoM Administrator
Get a vacuum gauge. Hunting around and visually checking the lines isn't really going to help you, you need to see what your actual vacuum levels are.
Old Sep 7, 2011 | 10:31 AM
  #70
hmmm now that's something to think about , maybe the increase in the trans coolers volume had a negitive effect on the vacuum.... ??
Old Sep 7, 2011 | 10:57 AM
  #71
That or maybe its simmilar issue to air in a clutching?
Old Sep 7, 2011 | 12:29 PM
  #72
dacib's Avatar
I had the transmission cooler after the I installed the cam. The problem was there before.
Old Sep 8, 2011 | 08:18 PM
  #73
Darewood's Avatar
Ok an update with my Ralliart, I see Dacib still has some issues with the A/T. Sounds like some progress has been made?
With my car I have cleaned out my intake portion and ran seafoam everywhere. Along with an oil change. I must say it gave me some power again It also helped where I lost power around the 5,800 range. I know I lost power now, but its not as dramatic. Before I would feel the car nose dive, but now its like a bump of power loss. But its still something that we need corrected.
Old Sep 12, 2011 | 03:04 PM
  #74
dacib's Avatar
Any news?
Old Sep 28, 2011 | 11:39 AM
  #75
dacib's Avatar
Any news?
