04-06 Ralliart Engine/Drivetrain (no forced induction)
tranny problems...still really
Old Nov 21, 2012 | 11:55 PM
  #136
lanzerralliart's Avatar
EvoM Super Moderator
You can remove the rubber or leave it in, I have done it both ways, the results feel the same
Old Nov 22, 2012 | 08:44 AM
  #137
CrAnSwIcK's Avatar
Rob, cut out the old and fill 'er up...i left the rubber in my rear mount, and it failed again...
Old Nov 24, 2012 | 01:29 PM
  #138
RallyartRob's Avatar
is there a place i can buy the urethane and do it myself? or should i get my friends dads place to do it for me?
Old Nov 24, 2012 | 03:15 PM
  #139
CrAnSwIcK's Avatar
if you got a place that can do it for a couple bucks, then sure, if it's cheaper than ordering from acklands grainger, i don't think they stock it, but you can go into your local store and order it in, usually takes a day or 2...look into it, Devcon flexane is pretty pricey up here in Canada. if somebody could do it for less than the DIY method, be it a liquid fill, or a machined bushing, then go for it.
Old Nov 24, 2012 | 08:44 PM
  #140
Canada_Comp's Avatar
When I blew my engine and had the mounts out, I filled both with silicone. It will take a while to cure but so far so good. Definitely not stiff like urethane, but I don't want the vibrations in my cabin. Just another option for fixing a cracked rubber mount for $5. I didn't remove the rubber when I did mine.
Old Nov 24, 2012 | 08:50 PM
  #141
what about this ? prothane 13-1904, its all 4 mount inserts for an eclipse tho from where ive found them probably under 100 shipped
Old Nov 24, 2012 | 09:19 PM
  #142
my friends, dads, shop makes all sorts of urethane products so they have all grades available from super soft to machinable hard, so ill ask him only problem i dont really want t remove the rear one cause its so hard to do i think. Also if i go to acklands graniger, what grade would i want or do they only stock one kind?
Old Nov 24, 2012 | 09:35 PM
  #143
$5 < $100 :P and don't you need to have a business to buy products from Acklands Graniger? I remember I was going to get something from there but then saw that they don't sell to the public, only registered businesses..
As for urethanes, I believe you would be looking for "castable urethanes". Devcon makes 2 kinds, 80, and 94. I'm not sure what grade the 80 is, but the 94 is a Shore A 97 hardness.
http://www.devcon.com/products/produ...%2080%20Liquid
http://www.devcon.com/products/produ...%2094%20Liquid
Old Nov 25, 2012 | 06:39 AM
  #144
CrAnSwIcK's Avatar
flexane 80 would be ideal, i used 3M window weld the first time, left the rubber in, it failed recently, so it lasted roughly a year and a half...though i push the car pretty hard. And i just walk into acklands grainger and buy stuff all the time...
Old Nov 25, 2012 | 08:09 AM
  #145
what about that protahne 13-904 i posted about? the inserts
Old Nov 25, 2012 | 08:22 AM
  #146
CrAnSwIcK's Avatar
i googled the part number and got very little return, are they for a 3g eclipse?
it's hard to say if they'll fit properly...
Old Nov 26, 2012 | 04:37 AM
  #147
sorry i missed a number copying from my first post the part number is prothane 13-1904, its all 4 mount inserts for a 2.4L eclipse 03-06ish year, tho from where ive found them probably under 100 shipped
Old Nov 26, 2012 | 06:36 AM
  #148
CrAnSwIcK's Avatar
it's a gamble...
Old Nov 29, 2012 | 07:42 AM
  #149
mitsubishi parts.net has a 10% off store wide disscout on right now go look under the specials arear to get this code it will tell u what is excluded
Coupon Code: bWAXNpw7
Coupon Desc: 10% OFF SITE WIDE
good till dec 12 i think
Old Nov 29, 2012 | 07:51 AM
  #150
johnnycage's Avatar
time for the timing belt and parts!, yeah baby!
