Adjusting Valve lash [advice?]
Old Jun 5, 2007 | 03:53 PM
  #136
Joho22's Avatar
Originally Posted by cfdfireman1
80+- 9 in/lbs = 5.9166666 to 7.4166666
Just get the fricken thing tight. Do you think anybody at the factory or dealership or anywhere else uses a tourqe wrench on a 10mm nut?
i dont know anyone in japan...
Old Jun 5, 2007 | 05:27 PM
  #137
Joho22's Avatar
so i called my friend whos advice was "dont touch it til i get there, unless you are going to use a magnet to find that nut."
i havent found that nut yet, but i need to find a clean container for all that oil.
ive check over that engine so many times... if its in the head, its invisible now.
Old Jun 5, 2007 | 05:34 PM
  #138
Eclipse2Lancer's Avatar
This thread has turned comical.......Joho I advise you to step away from your car and let your mechanically inclined buddy finish the job.
And never touch a torque wrench again!
j/k man.....but seriously..... reading torque specs > you
Old Jun 5, 2007 | 05:37 PM
  #139
Joho22's Avatar
i didnt use a torqu wrench!
id i did i would be set!
Old Jun 5, 2007 | 05:38 PM
  #140
otter's Avatar
EvoM Administrator
Alright, I'm going on vacation for a week. The rest of you keep trying to help this poor guy out.
Old Jun 5, 2007 | 05:39 PM
  #141
Joho22's Avatar
really, im taking a day off, tomorrow
im gonna try and do the oil and get the nut.
Old Jun 5, 2007 | 05:40 PM
  #142
Well then.....there's your problem right there!
Drink 6 of these AFTER you are done with your car:
Old Jun 5, 2007 | 05:41 PM
  #143
DangerousDan's Avatar
what otter said
no thanks
have you figured out the torque conversion joho?
Old Jun 5, 2007 | 05:51 PM
  #144
Joho22's Avatar
and you know i will...
Originally Posted by DangerousDan
no thanks
otter did it for me like 10 posts ago
Old Jun 5, 2007 | 05:54 PM
  #145
I mean have YOU figured it out
Old Jun 5, 2007 | 05:57 PM
  #146
Joho22's Avatar
i am totally going to mail you poop...
Old Jun 5, 2007 | 06:08 PM
  #147
KreepaEvoX's Avatar
I need to adjust valve lash again and this time Im overadjusting for added duration on exhaust
And NO I wont use a tq wrench...<-...the hell? no, Ouch!, what? (Joe Dirt)
Old Jun 5, 2007 | 06:09 PM
  #148
Joho22's Avatar
what?
Old Jun 5, 2007 | 06:12 PM
  #149
KreepaEvoX's Avatar
forget I said anything, DONT TRY IT!!! wait for D-Dan or Otter to explain it to you, my english aint that great when naming engine components
Old Jun 5, 2007 | 07:31 PM
  #150
tech#2's Avatar
Thumbs up valve lash adjustment.
Maaaaaan. This really shouldn't have been difficult at all. I know for a fact that the dealership would give you the procedure for adjusting the valves. The service manuals that you can get are not always correct. I can see the problem with the unmarked pulley. You still could have just pulled the #1 plug and felt for TDC then checked to see which rockers were loose. The mivec tolerences actually tend to tighten up over time. I check all of the valves and if they are a little stiff (feeler guage pull) Don't even bother. Same if they are a tiny bit loose. A five pound pull is industry standard for using a feeler guage. Just try rocking the arm with the guage in place. Good luck! Next time phone the dealership. If they won't help phone the next dealership and complain about what poor service yours has given you! Someone will help.........
