Adjusting Valve lash [advice?]
Old Jun 5, 2007 | 09:26 AM
  #106
drewbad's Avatar
joho--this is common sense, but your mind might be concentrating elsewhere. When you're almost done, to make things easier, you can dump your oil right on top of the rocker assembly instead of bolting the valve cover back on and pouring it in through the hole.
Old Jun 5, 2007 | 10:00 AM
  #107
Joho22's Avatar
hahaha!
you are right,
i wasnt thinking correctly...
that is a good point, but i still need a clean enough container that is large enough as well.
also, otter,
what the hell man, is there anything you dont know?
bruce, thanks for the info, but ill drop the $20 on the cheaper one at the place otter pointed out.
Old Jun 5, 2007 | 10:14 AM
  #108
otter's Avatar
EvoM Administrator
Plenty I don't know. Plus, I make a lot of mistakes, but I'm really good at learning from them.
Old Jun 5, 2007 | 10:19 AM
  #109
Joho22's Avatar
amen.
lets hope i follow suit.
Old Jun 5, 2007 | 10:21 AM
  #110
DangerousDan's Avatar
not me, I just kill the people who prove me wrong
Old Jun 5, 2007 | 10:23 AM
  #111
Joho22's Avatar
Engine block bolt and fuel rail bolt?
There is no oil pan gasket. You need to get that liquid gasket stuff designed for imports (the gray stuff.) Every auto parts store in the world will have it.
http://www.amazon.com/Permatex-ULTRA.../dp/B0002JN22W
If you have a Harbor Freight near you, you can pick up good torque wrenches for under $20.
http://www.harborfreight.com/cpi/cta...l_Store_ID=147
the block bolt... umm, there are 6 of them with multiple washers on them?
i lost one of those somewhere... (in usually much better with these i swear)
and i lost the other grade 7 bolt that goes on the brass braces that go between the 2 and 3 coils. (1 between 1-2 and the other 2-3). they are shorter than all the other bolts.
Old Jun 5, 2007 | 10:24 AM
  #112
Joho22's Avatar
sounds like my highschool learning environments
anyway,
otter,
you sure these guys will have a torque wrench with inch lbs?
if so thats only 20 mins away... and that would rule for 20$
Old Jun 5, 2007 | 10:30 AM
  #113
Joho22's Avatar
http://www.harborfreight.com/cpi/cta...452&pricetype=
score! actually... i might be wrong... doesnt say anything about gauging/measuring inch pounds...
Old Jun 5, 2007 | 10:39 AM
  #114
that is the opposite of what you need
Old Jun 5, 2007 | 10:44 AM
  #115
http://www.amazon.com/Pro-Quality-20...1065824&sr=8-1
gotta make sure it's inch pounds.
Old Jun 5, 2007 | 10:51 AM
  #116
otter's Avatar
EvoM Administrator
Harbor Freight has everything. It's the toy store of tools. If you go there, plan to spend some time just browsing, tons of obscure/cool stuff. The one near me stocks no less than 6 different kinds of torque wrenches.
this one - http://www.harborfreight.com/cpi/cta...temnumber=2696
or this one - http://www.harborfreight.com/cpi/cta...Itemnumber=807
Will work. I use the 3/8" one and just convert in/lbs to ft/lbs. Obviously, 12 in/lbs = 1 ft/lb.
Old Jun 5, 2007 | 10:53 AM
  #117
couldn't find those, HF's search engine isn't quite what amazons is
so that's the conversion huh?
Old Jun 5, 2007 | 10:54 AM
  #118
otter's Avatar
EvoM Administrator
HF's search sucks, their drill-down works better.
Old Jun 5, 2007 | 11:27 AM
  #119
Joho22's Avatar
https://www.evolutionm.net/forums/at...5&d=1180974607
that one registers 20-200 in pounds...
and the other is for ft lbs.
Old Jun 5, 2007 | 11:28 AM
  #120
otter's Avatar
EvoM Administrator
80+- 9 in/lbs = 7 ft/lbs.
