Adjusting Valve lash [advice?]
Old Jun 4, 2007 | 04:07 PM
  #76
bruce988jl's Avatar
You definitely didn't tighten something up...
Old Jun 4, 2007 | 04:09 PM
  #77
Joho22's Avatar
thanks...
can i get a plan of action...?
Old Jun 4, 2007 | 04:11 PM
  #78
otter's Avatar
EvoM Administrator
Originally Posted by Joho22
***OMFG!***
I have the absolute worst luck ever...
I tried, i failed...
might be time for a part out but i might be wrong...
thought i snugged everything good...
it went bad.
I took the car out after what i thought was a complete job.
it still had a minor sound,
so i took it back to the garage, and opened the engine,
to my absolute horror...
rocker 4 valve 2, the jam nut is gone.
someone PLEASE help...
If you don't see it somewhere up in the head, it most likely fell down into the oil pan. To get it out you could *try* to use a strong magnet to drag it over to the oil drain, but most likely you'll have to pull the oil pan to get it out. However, search the head thoroughly, first. With as fast as things move in there, it could've bounced around just about anywhere up there.
Old Jun 4, 2007 | 04:14 PM
  #79
Joho22's Avatar
well since i dont hear any REAL bad sounds,
i would ASSUME that its not messing up my engine yet...
should i drain my oil through a filtered funnel and check that, if not, take the oil pan off?
if not... pray the stealership doesnt rape my anus?
Old Jun 4, 2007 | 04:57 PM
  #80
cfdfireman1's Avatar
Well then
Originally Posted by cfdfireman1
This thread is scaring me, get help if you're not comfortable with this please, the other thread you linked to is convoluted at best. Here's the instructions from All-Data, there should be some resistance on the feeler gauge but not too much, you will only turn the crank once after you find TDC the first time and make sure the motor is HOT 176F to 203F. Good luck.
PS,
That sound you hear is your valve train being hammered to death.
Old Jun 4, 2007 | 05:37 PM
  #81
Joho22's Avatar
I felt comfortable at the time, its a little late for that now tho.... please offer any other worth while sugg's that would be worth try'n.
Old Jun 4, 2007 | 05:44 PM
  #82
drewbad's Avatar
it might be time
Joho22, you might want to research this.
Old Jun 4, 2007 | 05:48 PM
  #83
Joho22's Avatar
hilarious...
im really stressing here guys...
Old Jun 4, 2007 | 06:03 PM
  #84
Joho22's Avatar
would anyone happen to know where i could find a diagram / schematic of the lancers head?
Old Jun 4, 2007 | 06:05 PM
  #85
here
https://www.evolutionm.net/forums/at...4&d=1180974594
Old Jun 4, 2007 | 06:15 PM
  #86
Joho22's Avatar
............... Perhaps.... something... a little more detailed... not that Im not thankful for the help...... its just......
Well ok , how about an Exploded view?
And nothing like this .. unless you guys find some great pics .. then those are ok.
Old Jun 4, 2007 | 07:03 PM
  #87
Definitely time for some outside help.
Old Jun 4, 2007 | 07:10 PM
  #88
DangerousDan's Avatar
+1, if you screwed this up I would say be a bolt on boy. no offense, it's just that bad man.
Old Jun 4, 2007 | 08:33 PM
  #89
Joho22's Avatar
yeah,
i take no disrespect on that,
my own fault for not using a torque wrench...
i just kinda hd to go blow off some steam and such,
i think tomorrow i will drain the oil and
check the pan see if its in there,
hoping for the best,
worst case scenario, getting some friends to help take the engine apart and find that nut.
man, i dont understand how that happened. I was worried they were too tight...
yeah, i think i might have to take this to some family friends for some dismantle/re-assembly if its not in the oil pan
any ideas on what else i should do would be really appreciated...
im going to sleep.
Old Jun 4, 2007 | 08:41 PM
  #90
If it made it to the pan it should be ok there but if it's in the head against the cam somewhere that's a problem.
