Adjusting Valve lash [advice?]
Old Jun 5, 2007 | 11:32 AM
  #121
Joho22's Avatar
Originally Posted by otter
80+- 9 in/lbs = 7 ft/lbs.
9 inch lbs = 7 ft lbs?
huh?
Old Jun 5, 2007 | 11:42 AM
  #122
otter's Avatar
EvoM Administrator
80 in/lbs +- (plus/minus - the allowable variance) 9 in/lbs converts to around 7 ft/lbs.
80/12 = 6.66 ft/lbs, with a +- (allowable variance) of 9 in/lbs (.75 ft/lbs). So, 7 ft/lbs.
Old Jun 5, 2007 | 11:45 AM
  #123
Joho22's Avatar
ill change my avatar to a dunce cap soon, i promise.
so in order to get 9in/lbs i need to get 7ft/lbs?
Old Jun 5, 2007 | 12:10 PM
  #124
drewbad's Avatar
I should be the one wearing the dunce cap but I'm coming up with 9in/lbs = .75 ft/lbs.
Old Jun 5, 2007 | 12:33 PM
  #125
Joho22's Avatar
thats what i thought it should be!!!!
IM SO NOT WEARING THAT CAP!
Old Jun 5, 2007 | 12:35 PM
  #126
otter's Avatar
EvoM Administrator
You guys are reading it wrong. I typed 80 in/lbs with a variance (+-) of 9 in/lbs.
Old Jun 5, 2007 | 12:36 PM
  #127
Joho22's Avatar
but what marking do i need to get to on the TW?
  #128
cfdfireman1's Avatar
9/12=.75 sounds good to me.
Old Jun 5, 2007 | 12:44 PM
  #129
otter's Avatar
EvoM Administrator
*bangs head on desk repeatedly*
Ugh!!
  #130
otter's Avatar
EvoM Administrator
7 ft lbs.
I'll try one more time before I give up. You're trying to get 80 in lbs, which is 6.666 ft/lbs. There's an allowable variance (that means, you can torque that much above/below the target) of 9 in/lbs which converts to .75 ft/lbs. Take those two numbers and round to the nearest convenient number, and you get 7 ft/lbs.
Another way to explain variance. 80 in/lbs +- 9 in/lbs means that you must torque to a minimum of 71 in/lbs and a maximum of 89 in/lbs.
Old Jun 5, 2007 | 12:47 PM
  #131
Joho22's Avatar
math > otter?
stay tuned...
Old Jun 5, 2007 | 12:49 PM
  #132
otter's Avatar
EvoM Administrator
math > otter?
stay tuned...
No, typical torque specs > all of you.
  #133
drewbad's Avatar
HAHAHA! Joho22, seriously, set your torque wrench to 7ft lbs. This is what u want.
Old Jun 5, 2007 | 12:56 PM
  #134
Joho22's Avatar
evom > joho22
ill take whatever otter says anyway...
otter im sorry i ever doubted your,
can you ever forgive me?
Old Jun 5, 2007 | 03:17 PM
  #135
80+- 9 in/lbs = 5.9166666 to 7.4166666
Just get the fricken thing tight. Do you think anybody at the factory or dealership or anywhere else uses a tourqe wrench on a 10mm nut?
