Separate key for trunk?
Old Jul 7, 2009 | 12:55 PM
maxsideburn's Avatar
Ok, this is getting annoying. My key fob doesn't have a trunk release and my ignition key doesn't open the trunk, so my only option is to unlock the car, lean in, and pop the trunk.
Was the car supposed to come with a separate key for the trunk?
Old Jul 7, 2009 | 12:59 PM
otter's Avatar
EvoM Administrator
No, the ignition key opens the trunk. If it's not working, your lock is probably seized. Spray the inside of the lock with WD-40 and wiggle the key in there, see if you can break it loose (without breaking your key.)
Old Jul 7, 2009 | 02:20 PM
Thomar's Avatar
was the trunk lock ever changed for whatever reason?
Old Jul 7, 2009 | 03:57 PM
MUNDO's Avatar
mine is like this as well
Old Jul 7, 2009 | 04:08 PM
Arxylis's Avatar
Mine has done that a few times as well, but like Otter said, some WD-40 should do the trick.
Old Jul 7, 2009 | 05:04 PM
joeyj's Avatar
when i bought mine used over 2 1/2 years ago, it came with a separate key for the trunk.
Old Jul 7, 2009 | 05:22 PM
odd, so which is it? the ignition key or a separate key?
Old Jul 7, 2009 | 06:34 PM
otter's Avatar
EvoM Administrator
It's exactly what I said.
Old Jul 9, 2009 | 11:17 AM
RalliDew's Avatar
If you happen to have the Valet Key it will start the car and unlock the doors but wont open the trunk. maby thats the case if the WD-40 doesnt Work.
Old Jul 9, 2009 | 01:28 PM
Eclipse2Lancer's Avatar
We don't have a valet key AFAIK.
What I have noticed: key won't unlock trunk when all doors are locked. Unlock doors with FOB, then use key.
Old Jul 9, 2009 | 02:19 PM
otter's Avatar
EvoM Administrator
?? That's not right, either. My doors are always locked when I go to open my trunk with my key.
Old Jul 9, 2009 | 10:58 PM
dethrock's Avatar
Exactly what Otter said.
For my car, in the winter the lock won't turn very easy for the trunk. I have to wiggle it around a bit for it to open. In the summer though, it works just fine.
Both the key's i got with my car open both the doors as well as the trunk and I'm assuming everyone else is the same as well.
Old Jul 9, 2009 | 11:00 PM
Raikiri's Avatar
my keys do both doors and trunk locked or unlocked and also start car
Old Jul 10, 2009 | 06:12 AM
Well I tried some WD-40, it's not stuck, it just will not work with my ignition key. I will try the thing about unlocking the doors first.
k0lok0yboi
Mar 20, 2016 03:08 PM
blacksmoke43
Jan 22, 2015 07:36 AM
CjParsons19
Lancer Troubleshooting
Apr 14, 2014 08:23 PM
Kendogg
May 14, 2013 12:39 PM
LancerMarita
Sep 11, 2008 09:56 PM
