looking for anti-flicker solution
Old Oct 29, 2012 | 07:01 AM
Phukit's Avatar
Thanks guys, so what you both are saying is that I need both the relay harness and the anti-flicker capacitor to work for our Canadian DRL issues.
Also I found this guy selling a DRL Bypass module been on alot of forums and reported to work great on US DRL and even reported to have worked on a 06 lancer even though he makes them for the 08-10 lancers.
http://www.ebay.com/itm/170932772421...=p5197.c0.m619
anyone tried these?
If I disable them my DRL would just be the halo instead of the HID
Old Oct 29, 2012 | 04:03 PM
Canada_Comp's Avatar
anyone tried these?
I think you need a 9007 connector though to connect to the stock connector. unless your projectors came with an adapter.
Old Oct 29, 2012 | 04:30 PM
Phukit's Avatar
Yes I already have an adapter on there.
I ordered the bypass from ebay and will take the chance. I will report back on my results.
As my back up I will install the relay harness with capacitor and see if that works.
Old Oct 30, 2012 | 06:59 AM
QuanVN's Avatar
I tried all those anti-flickering devices and none of them worked, so I pulled the ecu and cut of of the pins. Did it 4 years ago, and I have no problems with my car and no DRL.
http://mitsunation.net/showthread.ph...running+lights
Old Oct 30, 2012 | 09:04 AM
Phukit's Avatar
Thanks but I am looking for a less permanent solution.
Maybe I will try to find a spare ECU from another ralliart and cut the pin off of that so I can always switch it back if I need to.
However I am hoping that this bypass works for me.
Old Oct 30, 2012 | 09:39 AM
QuanVN's Avatar
If you can find an ECU from a US ralliart even better, because you won't need to cut the pin. And this method can be reversed, just to to solder.
Old Nov 14, 2012 | 11:05 AM
Phukit's Avatar
Hey everyone, I just want to report back on the DRL Bypass
I got the DRL Bypass (made by jrox) in the mail today from ebay and installed it on my 06 Ralliart and I can CONFIRM it works as advertised and anyone wishing to eliminate anti-flicker and or eliminate your DRL you should definitely buy this relay/bypass.
It is very high quality build and I am very impressed on how well this worked! also there is no capacitor needed with this relay setup!!!
Old Nov 14, 2012 | 05:40 PM
CrAnSwIcK's Avatar
yeah? cool, so if it bypasses the DRL you wouldn't need the capacitor...good info
jessemoody
Sep 13, 2015 07:44 PM
sabotaaage
Apr 10, 2014 10:17 PM
EvoHead7
11
Mar 7, 2012 03:56 PM
bonbon0710
Lancer Troubleshooting
16
Sep 30, 2011 05:08 PM
jhkim45
Aug 27, 2010 07:21 AM
