Clutch vibrations when engaged @ high RPMs
Old Jun 5, 2013, 10:25 PM
Caviar's Avatar
Smile Clutch vibrations when engaged @ high RPMs
Today after taking an exit loop ramp pretty fast, I find when I am engaging the clutch at high RPMs to change gears, there is a vibration in my clutch pedal. I have been searching for what I should do and it seems everyone else gets this problem after some shop work has been done but mine happened randomly, I guess.
I am just wondering what I should do? new clutch? take it to a mitsu dealer?
thanks
Michael
Old Jun 6, 2013, 09:00 AM
CrAnSwIcK's Avatar
you mean disengaging?
Old Jun 6, 2013, 01:45 PM
RalliartN's Avatar
Is it vibrating/shuddering briefly as you bring your foot back up after shifting, and the clutch is catching?
Old Jun 7, 2013, 02:31 PM
Caviar's Avatar
No when I push down on the clutch pedal, the vibrations go with the rpm's and the vibration gets less and less until 3k it disappears. And a friend told me I probably wore out_________(I forget, I will ask again) something unevenly because I was sitting at high rpm's around this corner for quite a while.
thanks
Old Jun 7, 2013, 03:38 PM
CrAnSwIcK's Avatar
when you push the clutch pedal, you're disengaging the clutch. is the vibration quite violent? when you disengage the clutch, you've separated the engine from the transmission, so indicated RPM is engine rpm, not input shaft rpm. if the vibration correlates to engine rpm, either the vibration is from the engine, or the clutch is not disengaging properly
Old Jun 17, 2013, 04:19 PM
Caviar's Avatar
yes sorry when I disengage my clutch, I tightened one side of the engine mounts (seemed tight) but can't access the other side cause of too much stuff in the way, just haven't had time. but I have been driving slow ever since it started to vibrate and it went to normal (no vibrations up to 4K) until I start to boot (higher than 4500k) it and then the vibrations happen more again in the lower rpm like 3000k and more violent. But overall the vibrations are not that violent, just feel them in the clutch pedal and no noise and still a smooth ride.
I think I'm just going to take it to my mitsu dealer
Old Jun 17, 2013, 09:26 PM
CrAnSwIcK's Avatar
TOB might be ****ered...that's the only thing being used when you disengage the clutch...or maybe the pressure plate or flywheel is damaged...
Old Jun 18, 2013, 03:16 PM
Caviar's Avatar
Ya that's kinda what I'm leaning towards, one of those three. Thanks for the help man.
Ill post back on what I find out.
Old Aug 2, 2014, 03:15 PM
ekizenbe's Avatar
updates?
Old Aug 3, 2014, 12:22 PM
MarkChamorro's Avatar
I'm thinking its the TOB, you wouldn't be the first owner with a worn bearing lol
jamaicaboost
Sep 28, 2016 11:55 PM
seiya
Lancer Engine Management / Tuning Forums
Jul 26, 2012 09:43 AM
mean4g63
Jul 16, 2012 05:58 AM
fanbelted
Jul 3, 2009 08:23 AM
titaniumkingpin
12
Oct 12, 2005 07:48 AM
Quick Reply: Clutch vibrations when engaged @ high RPMs
