Gas Mileage Thread | [MERGED]
Old Oct 13, 2006 | 01:55 PM
  #136
michaeljr6's Avatar
pruius saves more.....lol
Old Oct 13, 2006 | 03:41 PM
  #137
ThyPunko_PR's Avatar
I got a Sportback RA with some mods...My worst was 17mpg (AutoX track day)....average 23mpg....my best 26mpg (highway): it depends a lot on the driving style and staying out of Mivec range (+3500rpm) as much as possible. Our 2.4L Mivec motor loves to drink gas...almost like a small V6-V8!!!
Old Oct 13, 2006 | 09:16 PM
  #138
cosworthrs500's Avatar
put a block of wood under the gas pedal
Old Oct 14, 2006 | 04:04 AM
  #139
richie1978's Avatar
Get an.....
Get an underdrive pulley from RRM. For myself, that has been the most successful improvement in MPG for my 2004 auto. RA!
Old Oct 14, 2006 | 06:16 AM
  #140
Achilles's Avatar
thats about normal i average 23mpg, but with mostly highway driving i can get up to or over 30mpg
Old Oct 14, 2006 | 06:17 AM
  #141
Achilles's Avatar
and about 40-50% of my driving is spirited.
Old Oct 14, 2006 | 08:42 AM
  #142
Ryan_VRX06's Avatar
Prius saves more?? Those things suck. A Diesel Volkswagen Lupo can get better mileage than a prius for the same amount of fuel. That and kids playing the street can't hear the Prius coming... grrrreat!
I've heard the K&N oval pod filter is a really beneficial for fuel economy and sounds great too
Old Oct 14, 2006 | 10:04 AM
  #143
Khobin~'s Avatar
same here, in the city I get around 23-24 mpg "spirited" driving (maybe a little better because my drive to work doesn't see a lot of lights), and on the hwy I get around 28-29 mpg.
...My xr get's 18-19 mpg(city) but that's just way too hard to stay out of the boost
Old Oct 16, 2006 | 06:46 AM
  #144
groundboundMU2's Avatar
I get around 26 mpg as an average in my Sportback, but I do about 70% highway driving on a tank. If I do more city driving, especially with the A/C on, I get around 23 mpg. I've seen as low as 20 mpg if I drive it hard with the A/C on in town.
My car is stock except for the K&N filter and I don't usually drive it too hard, try to anticipate traffic lights, accelerate moderately,etc. I do use Amsoil synthetic oil, changed every 7500 miles and ATF, currently at 64k miles and no problems.
Fuel mileage is my only real complaint with this car, but at least it's got the power to back it up. For a four-cyl wagon with an autobox anyway. My 89 Acura Legend only had 160hp and it was a 2.7 V6!
If the autobox had another gear, mileage would probably be much better. Our 06 2.4 4 cyl Accord returns about 32 mpg on the highway at 70-75 mph. Almost the same horsepower in a much larger car, yet it has a 5 spd auto. At 75 mph, the Accord is turning 2600 rpm, my Sportback is turning 3100 rpm.
Old Oct 22, 2006 | 02:46 AM
  #145
riceball777's Avatar
sounbds normal to me
my friends ra gets normally gets about 20-23mpg 24+ being on rare times with mostly freeway driving. i only get about 16mpg in my turbo integra
Old Oct 22, 2006 | 03:24 AM
  #146
EvoRecordSetter's Avatar
MPG depends almost fully on throttle position. so even if you shift low, you might be giving it more gas to get going, instead of reving higher with less throttle just leaving it the gear longer.
another thread was kind of about this, remember gas milage is not RPM based its throttle position. be easy on the gas!
Old Oct 22, 2006 | 05:59 AM
  #147
Myszkewicz's Avatar
I'm not so sure of that. I read that you can get better MPG out of a fuel injected car by shifting way early and flooring it to get going than going easy on the gas but revving higher. Because it's more about airflow than throttle position.
That old rule about pretending there's an egg between your foot and the gas pedal only applies to carbureted cars, then.
Old Oct 22, 2006 | 12:56 PM
  #148
EvoJutsu's Avatar
Change ur air filter.
Keep it under MIVEC, so 3500 or less.
Old Oct 22, 2006 | 08:03 PM
  #149
benny_ralliart's Avatar
ya gas milage in the RA isnt exactly excellent however, it definitly could be a lot worse.
Question though how does and underdrive pully get you better gas mileage?
Old Oct 22, 2006 | 08:12 PM
  #150
Myszkewicz's Avatar
It decreases the load on the engine by a tiny bit, which increases your fuel economy a tiny bit.
