updated wrx... what does this mean for the ralliart
Old Nov 10, 2008 | 02:25 PM
  #1036
ambystom01's Avatar
Originally Posted by Robevo RS
the modded RA sure will be over the 260hp. easy.
I think you mean the 260 whp. But even that shouldn't be a problem. Maybe even with just a tune.
I suspect 260 whp will require a freer flowing exhaust but 260 wtq might be achievable without one.
Old Nov 10, 2008 | 02:47 PM
  #1037
Robevo RS's Avatar
the "Experts" says in here the RA forum, the RA exhaust is a same as the Evo. and the evo exhaust you believe it or not is a pretty capable unit.
but you right, the exhaust will help, if the intake and the turbo can follow it.
Old Nov 10, 2008 | 02:55 PM
  #1038
Robevo RS's Avatar
It'll have the same effect. I don't even understand why we're arguing semantics, both cars have had issues but for the most part, the issues have been restricted to a small number of cars.
"It'll have the same effect."
i'm not argueing , i'm just telling you it is a big different. From personal experience.
When the throttle got disconnected the car is slows down in a calm way so basically you dont get a scare factor + you still got all the power steering, breaking etc stuff. The car goes to idle. No problemo.
The blow engine will stop working. Can cause wheel stops, drive train damage, loss power steering , breaking problems , and you got the scare factor for sure . Which can lead confusion and so on.
I got a engine blow situation in the winter and that was really scary .. In the turn aroun 60 mph.
Also at my old Lancia i got the trhottle linkage broke, was no problem to control a car and take it to stop.
When actually happens both with you you will understand the difference, even if its "sounds similar problem"
Old Nov 10, 2008 | 03:30 PM
  #1039
ambystom01's Avatar
The exhaust isn't the problem so much as the turbo.
Old Nov 10, 2008 | 03:31 PM
  #1040
ambystom01's Avatar
I've had an engine blow while I was driving and all that happened was I lost power, it didn't lock up the tires, I didn't lose control, I just lost power.
Old Nov 10, 2008 | 03:38 PM
  #1041
Robevo RS's Avatar
on awd is hard to lock it up ,unless its slippery. also if your engine can still turn, it will not lock the tires. But the slowing down is still more stronger and rapid vs the engine which is idles. And without working engine all the power steering will go soon
period.
Old Nov 10, 2008 | 03:41 PM
  #1042
ambystom01's Avatar
That was on a FWD car. It slowed down faster but it wasn't anymore than if I had pushed in the clutch pedal.
  #1043
Robevo RS's Avatar
the number one solution
Old Nov 10, 2008 | 05:23 PM
  #1044
dboz's Avatar
Originally Posted by spicaly
when do you guys think we'd see info about the 2010 ralliart to know if anything changed?
Figure on a 5 speed for 2010.
Old Nov 12, 2008 | 01:02 PM
  #1045
kyoo's Avatar
+1 a five speed will definitely make me consider it..
And seeing as the wrx comes only with the manual I would think that Mitsu would at least provide the option of it? Or do they want to force those people to upsell to the evo
Old Nov 12, 2008 | 01:05 PM
  #1046
Robevo RS's Avatar
they might even fix the SST problems and then i'm sure there will be an after market solution too for the RA in 2010.
Old Nov 12, 2008 | 01:21 PM
  #1047
EsRt2evo's Avatar
No problems yet for the RA SST.
xmystikx
Jan 28, 2016 11:07 AM
Ralliart_on_LSD
39
Feb 5, 2014 02:10 PM
ETS Michael
ExtremeTurboSystems.com – WA
Jul 10, 2011 01:26 PM
DeeezNuuuts83
Mar 20, 2008 10:45 AM
