TTP-Engineering Tunes the 2009 Ralliart 4b11
Yes, I have an X MAS sitting in my garage, was gonna try to make it work on a DSM. The X uses a much better hotwire style sensor than the previous DSM sensors.
1G MAFs were Karmann sensors, small restrictive passage but you could hack them to flow alot more. I went 12.1 on a hacked 1G MAF with a stock turbo. People have gone 10s on them. The 2G MAF is physically only slightly larger in terms of flow than a hacked 1G, but it's metering capability is higher. It'll work up to about 50 lb/min without missing counts. People have also been swapping EVO MAFs into DSMs lately. We ran one on a friend's car, saw 63 lb/min without any erratic readings.
I remember hacking out the honeycomb from the MAF on my 1G... Though the car was so screwed in the first place, I don't remember if it made it any better or worse.
"All factory turbo cars run rich as ***** so they don't blow up in warranty."
That's what I figured.
Does the RalliART run rich? I don't see how burning extra fuel would help the engine not blow up.
