TTP-Engineering Tunes the 2009 Ralliart 4b11
Old Dec 10, 2008 | 04:03 PM
  #226
angryGTS's Avatar
Originally Posted by ambystom01
If we could dyno the Ralliart along with the Evo, it'd be very helpful.
Ya with the MR though since they have the same type of tranny
Old Dec 10, 2008 | 04:05 PM
  #227
ambystom01's Avatar
Not completely necessary but it'd help a bit. It's next to impossible to get a completely 100% accurate idea of how two cars compare if they have a different drivetrain (like the Evo and Ralliart have).
  #228
35rEvo's Avatar
How do you compare two separate dyno results?
Maybe I'm just stupid today, but I don't understand what your trying to say. The car baselined at 216whp/238wtq and resulted in 243whp/265wtq with the z-chip. There was a 27whp increase.
Old Dec 10, 2008 | 04:06 PM
  #229
angryGTS's Avatar
yep
Old Dec 10, 2008 | 04:08 PM
  #230
ambystom01's Avatar
Some people were claiming that the 216 whp base run was proof that the Ralliart was underrated. I suggested that the dyno was high reading using a previously produced dyno from TTP as proof. I went on to suggest that it doesn't make much sense that the Ralliart dynos 14 WTQ less than the Evo thus further insinuating it's a high reading run.
Old Dec 10, 2008 | 04:09 PM
  #231
Robevo RS's Avatar
the 27 whp is the part where you want to pay attention. The gain.
Old Dec 10, 2008 | 04:11 PM
  #232
ambystom01's Avatar
Yep, 27 WHP is a pretty damn good gain for a single mod.
  #233
35rEvo's Avatar
I understand the first part of what you are saying. But, what are you implying in the bold?
Old Dec 10, 2008 | 04:12 PM
  #234
angryGTS's Avatar
Some people claim Mustang dynos throw out numbers of hp that actually touch the ground(hard to explain exactly how Ive heard many times from different people) where a DynoJet give higher numbers. wasnt this done on a Mustang dyno or maybe just isnt calibrated to the new hp rating standard?
Old Dec 10, 2008 | 04:18 PM
  #235
Robevo RS's Avatar
The Mustang dyno reads lower then Dynojet.
TTP using mustang dyno.
Old Dec 10, 2008 | 04:28 PM
  #236
Dennis F's Avatar
Deleted.
Old Dec 10, 2008 | 04:41 PM
  #237
ambystom01's Avatar
Look back, the Evo dynoed at 256 WTQ while the Ralliart dynoed at 242 WTQ, a 14 WTQ difference despite a 47 ft-lbs difference between the reported values for the cars.
Old Dec 10, 2008 | 04:42 PM
  #238
angryGTS's Avatar
Ok just making sure.
Old Dec 10, 2008 | 04:44 PM
  #239
ambystom01's Avatar
Originally Posted by Dennis F
I am so confused with this mess of a thread.
The Evo and R/A have the same motor. Without knowing what the VE is while comparing the 2 cars, I do not see why the R/A would not be that close to the Evo as far as TQ goes. The turbo is said to be a little smaller, but by how much? What airflow are both of these cars at by 5252 rpm that there would be a bigger difference???
Amby, are you saying the R/A should not make those numbers? What exactly are you trying to get at?
I honestly would expect the R/A to not be to far behind Both are 2.0, both have the same value as RPM's go up and airflow is airflow. It looks like boost falls of quicker vrs the Evo, but that could be fixed. After a reflash I would expect even a closer gap as far as HP goes.
I also don't see where your going trying to compare the 2 cars, they can't be overlayed and then say they perform differently (I think maybe you are saying this) but the Evo is more aggresivly tuned.
You could also look at the 1st and 2nd gen DSM's. 1g was rated at 195hp and the 2g was 225hp but the 14b was a much better turbo
The two cars have different turbos, intakes and intercoolers, all the share is the short block.
The Ralliart is rated at 237 HP and 253 ft-lbs of torque. I believe this is what it makes given the performance numbers and the fact that I see no reason to doubt a manufacturer. What I am saying is that the base numbers presented here are high, that is all. They're not wrong, they're not fishy, they're just high. Trying to compare them to other results is a waste of time, the same car can have a 100 HP variance from dyno to dyno.
Old Dec 10, 2008 | 05:08 PM
  #240
dboz's Avatar
Wow, miss a day, miss alot (8pages)....not really. I feel like I am in a dryer....round and round.
TTP, just curious if the RA you installed the Zchip on, is a member on this forum. I was looking forward to reading a review and if any changes have been noticed in MPG etc.
Also, if you could keep us posted if you do any more RA tuning that would be great. Seeing if things stay pretty consistent car to car.
