TTP-Engineering Tunes the 2009 Ralliart 4b11
The Lancer GTS was getting 26mpg in the city FWD/non turbo and the R/A is getting 21-22/city AWD Turbo at 19psi w/o tune and that is not good?
I would say it is.
The GTS is excellent in gas and the R/A is 6mpg shy from the GTS?
now i agree with the tune, and more hp to counter the weight of the car, yes, you should get a better MPG. But on a non-tune car in comparison to the GTS.
I still say that is pretty damn good.
My boy has a 2008 AWD RIDGELINE and the sticker says it gets 15mpg/city and the real time driving is getting 11-17mpg/city.
I would say it is.
I'm just shocked that the RA is running 19 PSI, that doesn't give you much room to expand. It also doesn't translate for me, a WRX running 14ish PSI from a TD04-13T makes 224 HP (2.0 L model) yet a Ralliart running 19 PSI with a larger turbo makes about the same power? Something doesn't add up.
I would say it is.
I would say it is.
The recommended break-in procedure and mileage is in the owners manual. Just follow it and you'll be fine. I haven't seen a new vehicle in a long time that doesn't list the break-in recommendations.
