TTP-Engineering Tunes the 2009 Ralliart 4b11
So if the company that engineers the car is worried about the trans taking the power, why would you be ignorant enough to think you know more than them and mod it to do it anyway...unless you just have a lot of money to waste and don't mind replacing transmissions on a regular basis.
Also, the torque numbers for the transmission are known for the SST as established by Getrag. Do you think you know more than them also?
No I don't. I am just being a realist. You can fantasize all you want. If someone wants to take the chance with their transmission and have a tuner try to EXPLORE the limits, then sign up. I am sure as long as you sign off on liability and pay for the replacement, someone will be glad to test it for you.
Sometimes the truth hurts. Maybe there will be a fix. I find it hard to believe that you all think there is some underrating conspiracy with the SST. So Getrag, Mitsu, TTP and the rest are all conspiring to keep the REAL number a secret.
Its good for what it is and does. As TTP mentions early on a RA 5 speed lightweight edition would be killer. Do you really need to read between the lines anymore? The engine probably has was more left, unfortunately the transmission does not.
We can stop pounding our heads against the wall trying to grasp this fact.
OK, I am with you. Sorry for being negative. I am all for someone offering up there car for further exploration into its limits. The lesson "better safe than sorry" has not been learned by you young guys yet. I am not going to make a multi thousand dollar mistake testing your limit theories but if you are willing, I am sure there will be someone who will find out for you.
The whole point is to tune a car to safe levels. There will always be someone who wants to go beyond at his own peril. Good luck, I look forward to seeing the results and the breakthrough, with the emphasis on break.
Some people are confusing torque with horsepower. Just because it's torque limited doesn't mean it's power limited. I'm guessing that the EVO X turbo/manifold will swap on, if so that'll add some top end power gains without increasing midrange torque if it's tuned correctly.
And the RA tranny is tuned for less RPM range then a X. if i'm right around 6500. SO if you raised that to 7600 fuel cut as a Stock evo have it, might the SST ECU will not tolerate that, and will cut it just as it did with the TQ.
The tranny ECU have connection with the engine ECU. So you can change the engine ecu but nobody did the SST ecu yet. I dont think that is right.
So who knows? I'm just thinking loud.
I hope i'm wrong on this one.
Take a look at the dyno graph on the first page. The torque falls off a cliff over 5500. With a stock X turbo, you'd be able to maintain way more torque through 5500-6500. Even without raising the rev limiter I'd think the top end gains would far outweigh the mimimal spool difference. Don't that the X turbo is twin scroll so you're really not sacrificing much down low to gain up high.
a way i see it:
the turbo is for tq, the Rpm is for hp...that is why the rally cars running 500nm and only 300 hp
The tq to bring you up, the hp will keep you there.
The Mivec is a real help on top rpm and not the turbo.
Bigger the turbo is you can go higher, but then you start loosing bottom end. Or vice versa
So there is a fine balance. Which is the evo kinda maintaine with the twin scroll. Or the titanuim turbine wheel on some older evo ,like TME or earlier evo RS'.
Th RA small turbo kicks sooner but dies sooner.
Only thing is in the RA set up gives you top HP is the Mivec with higher rpm. So just like the V-tech. Needs RPM.
And that is why you need to raise the RPM if you want more peak hp. We know the TQ is limited via TCU.
Logically the rpm is have to be a same way. So the TCU will limit that one too.
Now the RA being already 1000rpm lower fuel cut raise the question , how much really HP an tq the TCU will actually allow?
We "know" now not much tq. SO i guess will be a same with the hp too. The TCU will not allow too much raised rpm.
a way i see it:
Rob, I see you post all over these forums and you really have no mechanical knowledge.
Funny. Steve93Talon is a well respected DSM enthusiast and how he is explaining TQ and HP is going well over your head. The TCU only monitors TORQUE. IF you look at dyno graphs, you will notice how torque drops off towards the top-end mostly due to the fact that engive VE is dropping. We DO have 4 cylinder motors. The drop off is the advantage. While torque is dropping, the twin scroll turbo setup would increase top end HP. The SST ecu is happy since the torque is going down but the butt dyno is also happy with the increased HP.
Understand now?
Understand now?
Understand now?
thanks
But not really.
Cabn you make it little more understandable for me ?
