TTP-Engineering Tunes the 2009 Ralliart 4b11
Old Dec 9, 2008 | 01:02 PM
  #91
EsRt2evo's Avatar
Originally Posted by ambystom01
I'm just shocked that the RA is running 19 PSI, that doesn't give you much room to expand. It also doesn't translate for me, a WRX running 14ish PSI from a TD04-13T makes 224 HP (2.0 L model) yet a Ralliart running 19 PSI with a larger turbo makes about the same power? Something doesn't add up.
The RA is underrated, simple as that.
Old Dec 9, 2008 | 01:04 PM
  #92
ambystom01's Avatar
Except that makes no sense considering the performance numbers, it performs just as it should.
Old Dec 9, 2008 | 01:11 PM
  #93
EsRt2evo's Avatar
Whoops. Reading > me
Just because its "underrated" doesnt mean its going to be godly fast. My old civic could have been rated at 125 hp, yet put down 120whp and it still would have been considered underrated.
Old Dec 9, 2008 | 01:18 PM
  #94
ambystom01's Avatar
The numbers that aren't "up to par" are the 0-60 times, the 0-100 times and the 1/4 mile times, they make sense in light of the listed power and the listed weight but if the Ralliart is indeed underrated, they seem anemic.
Old Dec 9, 2008 | 01:46 PM
  #95
EsRt2evo's Avatar
The numbers seem right to me.
Old Dec 9, 2008 | 01:49 PM
  #96
ambystom01's Avatar
Just because you dyno at 120 WHP doesn't mean the car is underrated. As far as we know, that dyno reads high. Too many people think that a high dyno number means the car is underrated or a low number means the dyno is broken. Some lancer people put down 110-120 WHP stock yet the car makes 120 HP at the crank. Of course they claim the car is underrated or they gained 10 HP with their intake and catback exhaust but they're wrong. When you compare the numbers to another car on the same dyno *gasp*, they fit.
Old Dec 9, 2008 | 01:50 PM
  #97
ambystom01's Avatar
Yeah the stock numbers fit the performance. What I find strange is that the car is pushing 19 PSI yet it only makes 237 HP.
Old Dec 9, 2008 | 02:31 PM
  #98
angryGTS's Avatar
Ya, its gotta be the stock tune holding it back, should be in the 260s at least.
Old Dec 9, 2008 | 02:34 PM
  #99
ambystom01's Avatar
I don't know if that makes sense either. It may running a bit rich but it looks like the boost comes on so early (3200ish) that it basically falls flat on its face by the time redline approaches. 19 PSI at 3200 RPM is pretty crazy.
Old Dec 9, 2008 | 02:39 PM
  #100
angryGTS's Avatar
Ya very true
Old Dec 9, 2008 | 03:12 PM
  #101
chino ali's Avatar
Originally Posted by dboz
Mine is an 06 with 50k. I have NEVER gotten below 18MPG on a tank since owning it for 38 months now. And I drive hard every day.
cool.
i only know of the 08 Ridgeline and from what I seen, it's terrible on gas.
But he has only owned it for 7 months.
Still, tho he should be getting at least equal to your 06 or better.
But he doesn't. He gets those numbers and + in the highway and I managed to see 24mpg.
That still doesn't negate the fact that 21-22city for the R/A isn't good.
Given the weight it's draggin.
I mean it is the heaviest car in it's class.
It will def benefit in fuel from a tune.
Old Dec 9, 2008 | 03:14 PM
  #102
chino ali's Avatar
well.
actually the boost comes at around 22-2300.
In truth you can almost hear the spool as soon as you take off.
Old Dec 9, 2008 | 03:15 PM
  #103
ambystom01's Avatar
Look at where the boost peaks, it's at around 3200 RPM.
Old Dec 9, 2008 | 03:20 PM
  #104
chino ali's Avatar
oh at peak, at 3200 yes that is right.
i was referring to this line.
It starts to spool at 2200rpms.
Old Dec 9, 2008 | 03:23 PM
  #105
ambystom01's Avatar
That's about where I start to spool too. I hit full boost at around the same point as well.
