TTP-Engineering Tunes the 2009 Ralliart 4b11
Old Dec 11, 2008 | 05:02 PM
  #271
ambystom01's Avatar
Originally Posted by EsRt2evo
The issue is YOU thinking your answer is the only one that matters. Let me say this again: 237 claimed crank horsepower does not equal 220 proven whp. Therefore it is UNDERRATED. So RobevoRS posts a 0-60 time of 6.6, yet you fail to say anything about that. Its the worst # possible obtained by anyone, yet you just agree with it because it supports your argument. Unbelieveable.
When have I ever said my way is the only way? So far the only "proof" you have of your claim is that the car makes 220 WHP on this dyno but you haven't even put that into context. If I just throw a number out to you, let's say 180 WHP, does this mean my car is underrated or overrated? You have several people dismissing your claim (one of which has posted a very good response) yet you choose to stand by it even though you yourself can't support it. I also did respond to the post by Robevo (or rather the post against his) but like most people, I have a job and couldn't be on evom to reply to every damn response. I find it absolutely hilarious how you claim I agreed with his post when I didn't say anything.
Old Dec 11, 2008 | 05:03 PM
  #272
ambystom01's Avatar
Originally Posted by madcows
I thought I made myself pretty clear that I think it would be unfair to compare the evo to the SS. My point is that I find the comparison of the R/A, and SS equally unfair. From my perspective, they're totally different cars. So, how can you compare totally different cars? You can't. If you try, it's strictly opinion, or subjective.
I'm not missing any factors regarding the drivetrain. That's a FACT. Sorry if it offends you, but you either lack knowledge in the involved mechanical principals, or you're just purposely trolling, amby.
You restated what I already did regarding the diffs. Yes, the evo has different front and rear diffs than the R/A. The difference however, will be totally negligible on a dyno. In fact, since the evo doesn't use traditional mechanical limited slips, there is a good possibility that the diffs in the evo have less mass than the ones in the R/A, so in reality, the evo might have slightly less drivetrain loss. But again, the difference would certainly be unnoticeable.
Remember, differentials are practically passive unless their is either a difference in grip between opposing wheels, or if they're rotating at different speeds - both conditions that do not occur on a dyno.
Also, I won't stand behind any claim of the R/A being underrated compared to an evo. Though, I will support that it IS A POSSIBILITY. Whether it makes sense or not. I believe back in the 70s, chrysler had a motor that was spec'd at 400-some-odd horsepower. When that motor was taken to an independent dyno shop, they found that it made power more in the neighborhood for 800HP! Why would they say it only made 400? You can ponder on that a bit.
Again, by that exact argument, you can't compare any car to any other car.
As for the rest, I and others have already responded to it.
Old Dec 11, 2008 | 08:14 PM
  #273
Dennis F's Avatar
Deleted.
Old Dec 11, 2008 | 08:26 PM
  #274
ambystom01's Avatar
We cannot compare the two dynos, they were made at completely different times. Again, the diffs are relevant because the power has to go through them before it hits the wheels.
Old Dec 11, 2008 | 08:31 PM
  #275
madcows's Avatar
The only relevance the diffs play in dyno results is due to any drag they impart because of their mass, and any friction (which should be minimal). So unless the diff guts weight 50lbs or more, they make practically no difference.
Are you trolling again?
Old Dec 11, 2008 | 08:44 PM
  #276
ambystom01's Avatar
You're seriously going to continue arguing this point after being told you were wrong by at least 3 separate people? How are the diffs not relevant? Does the power magically avoid them? The whole idea of diffs works on friction, why do you think AWD cars always dyno significantly less than their similarly powered FWD or RWD counterparts? As for the rest, yes, I've been a member for 5 years, I have over 10000 posts and I'm a moderator but yep, you got me, I'm a big old troll.
Old Dec 11, 2008 | 09:29 PM
  #277
madcows's Avatar
Either a troll, or lack the ability to reason.
I would say your argument would have merit if they didn't have the same center diff, but they do.
It's better if you look at diffs as devices that maintaining traction either when one wheel is slipping, or when wheels opposite to each other a spinning at different rates (and therefore, in a sense, slipping). these are things that don't, or at least shouldn't occur on a dyno.
So again, unless one car has a diff from a quad, and the other from a tractor, losses due to the differences in mass, and friction will practically make no difference. It doesn't matter if the diffs are open-type, or s-awc type: not a dyno.
You apparently have poor mechanical aptitude. My intention isn't so much to prove you wrong, but rather enlighten you on your misunderstanding.
Just because I made a mistake on an unrelated issue, doesn't make everything I say wrong. Unlike you, though, I will admit when there is an error on my part.
Old Dec 11, 2008 | 09:34 PM
  #278
ambystom01's Avatar
Funny how you say I can't reason yet you've yet to provide a rational argument supporting your claim in the face of multiple objectors.
I am well aware of what diffs do but the major factor you are missing is that any and all engine power has to pass through the differentials before it hits the ground. Should we also dismiss the transmission in our discussion?
I freely admit when I make a mistake but in this case I am not. Moreover, I tend to listen a whole lot better when someone with more than 23 posts is talking, especially when that person hasn't even established themselves in a light other than someone who just jumps down my throat. If you came on and showed strong mechanical skills, I'd be all ears but given the last few posts, I'm not so inclined.
Old Dec 11, 2008 | 09:50 PM
  #279
madcows's Avatar
So, you know all about cars because you have 8549958439058439 posts on a forum? Hmmm... Funny, I would make a similar claim because I worked on cars as far back as I can remember. It may also help the much of my family, and friends (including me) are engineers (of various disciplines), master mechanics and technicians. Also, this isn't the only car forum in the world. The only reason I post here is because of my interest in the R/A.
Yes, the power goes from the trans (or in this case, the center diff) to the wheel diffs, to the rims, then the tires, and finally, through friction - to the dyno.
How much HP would you say the front, and rear diffs are eating up? Do you really thing that the s-awc diff eats up substantially more or less hp than the mechanical limited slips? - this is the point. I won't bother anymore. If you truly cannot grasp this, then it's your loss.
No one argued this point
Old Dec 11, 2008 | 09:52 PM
  #280
madcows's Avatar
LOL
I showed strong mechanical skills. You just don't understand them. Sorry.. It's not my fault.
Old Dec 11, 2008 | 09:53 PM
  #281
ambystom01's Avatar
We have no idea how much (specifically) the diffs are eating up but you cannot dismiss them, that is poor science.
I really don't care about your claims because this is the internet, everyone can claim to be whatever they want. However, since you have yet to establish yourself, I'm not exactly going to instantly trust what you have to say, especially when it goes against logic.
Old Dec 11, 2008 | 09:54 PM
  #282
ambystom01's Avatar
LOL
You sure did, I guess I should stop listening to the tuners and just listen to you .
Old Dec 11, 2008 | 10:07 PM
  #283
madcows's Avatar
No, we don't know specifically. But we (most people, not you) know that they are not going to be significantly different from one another. Since the rest of the system is practically identical, we can get good indication of the difference in power between the engines alone.
If we really want to get into it, the difference in weight of the wheels/tires is most likely more significant than weight of the diffs.
I don't know what school of logic you came from.
Old Dec 11, 2008 | 11:48 PM
  #284
EVO Neil's Avatar
Originally Posted by Robevo RS
thanks
Now only if madcows and the other know-it-alls would look at the information about SAE testing standard J1349 it's how Mitsubishi (and most manufacturers) rate their engines. Why did you ignore this to continue your pointless arguement with ambystom01 about differentials?
Did you even review what I posted?? Let me put it up again...I've answered the J1349 rating standard for modern engines for those conspiracy theorists about hp ratings. But for those that would like to educate themselves further...
http://www.sae.org/certifiedpower/details.htm
or more here:
http://www.land-and-sea.com/dyno-tec...horsepower.htm
Old Dec 12, 2008 | 12:24 AM
  #285
C2Rally's Avatar
or more here:
I couldnt find any info regarding diffs in the first link and I got bored reading the second link, could you post that part??
