Whack!!! wtf
Old Oct 23, 2009 | 06:17 AM
  #46
xi's Avatar
xi
Originally Posted by clifhanger87
blow off
problem solved...
I'm gonna stuff like 4 of those into my car. Quad turbo.
Old Oct 23, 2009 | 06:26 AM
  #47
eldiablo79's Avatar
Originally Posted by TTP Engineering
silly Ralliart owners...
If it is installed correctly, then its doing its job. Its an upgrade for boost holding capacity because the stock Ralliart valve is plastic.
If you want the vroom vroom pshhht sound, then you should have bought an SRT-4.
It's funny cause it's true!
Old Oct 24, 2009 | 07:33 AM
  #48
lookitznite's Avatar
buying stock EVO9 BOV wont give you that swooosh noise....I got that first then got the UR intake then you will hear the swoosh...now I got the TURBOSMART DUAL PORT BOV and its even much louder now though....
Old Oct 24, 2009 | 08:01 AM
  #49
RA Glows's Avatar
Is the Turbosmart recirculating??
Old Oct 24, 2009 | 10:24 AM
  #50
Old Oct 24, 2009 | 11:49 AM
  #51
Taranis's Avatar
It can bet setup as recirculating or VTA I believe. =)
-Taranis
Old Oct 24, 2009 | 12:11 PM
  #52
Smike's Avatar
VTA - bad. Well covered here.
The IX and X DV (BOV) does not make noise, its not mean to. If you want to hear the sound, others have covered it - intake (cone filter) and a different DV(BOV).
Word of caution - some DVs will give you nothing but headaches. Not talking A/F issues but bucking and drivability issues. I would put in a good amount of research into which brand you get. The I-IX area has a good amount on that.
I ran the Forge RS, which can have bucking issues if you are not used to going on/off throttle. If you try to slowly back out, it will shutter the car (right otter ). But full off - not an issue. I ran it because I needed it to hold the boost I was running, and it was "tunable" with the adjustable spring setting.
Old Oct 24, 2009 | 02:15 PM
  #53
TTP Engineering's Avatar
Turbosmart is crap. Just invest in a valve that serves it FUNCTION!
If its attention you are after, paint it this color.
Old Oct 25, 2009 | 06:37 AM
  #54
sofly1990's Avatar
one of my boys has a evo 9 with a vta bov and he has no prob also other boy of mine has a sti which is vta and none of them have any problems
Old Oct 25, 2009 | 09:39 AM
  #55
Ladogaboy's Avatar
One of my boys had a 2nd Gen GSX, and his car would sputter and die after a high rev when he installed a VTA BOV. He had to get a separate unit that told the ECU to compensate for the lost air before his car was drivable again.
My boy...
Old Oct 25, 2009 | 02:45 PM
  #56
Taranis's Avatar
My boy...
Unless the car has an adaptive ECU you would need a tune of course to make it run properly because the car is expecting the recirculated air to be returned.
-Taranis
Old Oct 25, 2009 | 03:16 PM
  #57
Ladogaboy's Avatar
Originally Posted by prodigalsunn
wow, i found a vendor i'll never buy from!!!, what a d-bag!!! why is everyone hating? the fact that he junked his VTA valve for this one should give him applause. plus i don't know why everyone hates VTA BOV's so much, they work fine with a proper tune.
I dislike them because most of them are designed with the sole purpose of annoying bystanders. Combine that with the fact that, even with ECU tuning, they are no more effective than recirculating units and you have a worthless, unnecessary mod.
Old Oct 25, 2009 | 03:35 PM
  #58
RevLimiter's Avatar
I installed the ams replacement bov and an Injen cold air intake and i get an awesone sound!!!
Old Oct 25, 2009 | 04:54 PM
  #59
Smike's Avatar
And with that. Closed. OP - search and read about VTA with MAF systems.
Vivid Racing
12
Jul 30, 2014 03:40 PM
gotrnet
Jun 11, 2008 09:27 AM
Jie-EVO
30
Jan 24, 2007 08:23 AM
05evo
11
Jun 14, 2005 12:56 AM
ku7484
Apr 12, 2004 05:09 AM
