Transmission dead
Old Sep 24, 2010 | 11:41 AM
  #76
erics01's Avatar
Is the fluid specific to the SST, or is it just regular tranny fluid that I can pick up from any auto parts store? I'm sure the dealer wants to charge an arm and a leg to change the fluid, so is it easy enough that I could change it myself?
Old Sep 24, 2010 | 11:49 AM
  #77
jkennedy293's Avatar
The SST requires specific SST fluid. I would recommend using Mitsubishi's DiaQueen, as may use the use of an alternative fluid as a reason to deny a warranty claim. I think it goes for about $100/ gal, and there is a specific process involved in changing it out. Its not just a drain and refill. If you check the EvoX forums, someone posted the scheduled maintenance instructions from the service manual, and it is detailed there.
When it comes time for my SST fluid change, I will be taking mine to the dealer. It may cost more than doing it myself, but at least I'm covered if something goes wrong.
Old Sep 24, 2010 | 12:04 PM
  #78
erics01's Avatar
Sounds involved, I'll leave it to the pros.
Old Sep 24, 2010 | 12:57 PM
  #79
migs647's Avatar
^------ this. I'll be doing the same thing. That way they can also see I'm taking care of the transmission if a time comes when something goes wrong.
quickflips
Jan 9, 2014 05:44 PM
lmles
Aug 27, 2013 09:33 AM
YuLost2x
Sep 25, 2012 04:31 AM
Insanity Evo
May 31, 2011 05:11 PM
BlackOps
May 27, 2010 01:00 AM
