Headliner Rattle
Old Jan 8, 2013 | 11:13 AM
p1llar's Avatar
Headliner Rattle
After switching my exhaust from DC Sports to Magnaflow my car devloped a brutal rattle above the drivers said head in the headliner. Between 1,500 - 1,750 is vibrates loud, when you place your hand on the headliner it stops. It is driving me insane, the dashboard & glovebox rattles too, which I can put up with but the headliner is so loud that people can hear it in the back seats.
Has anyone else had this issue? did you have to pull the headliner and put some dynamat down or something?
Old Jan 8, 2013 | 11:19 AM
neogeo64's Avatar
Im stock and have a slight rattle there as well. I have a moon roof so the liner is lower but sounds like its in the same spot as yours.
I think stick on felt would be a lot cheaper and lighter to try on the edges of the liner that are in contact with the roof. The stick on felt is also good for the door panel and dash vibrations. If you do pull it down take some pictures.
Old Jan 8, 2013 | 12:01 PM
p1llar's Avatar
Thanks for the tip. I just don't want take apart the headliner and have issues getting it back in and looking good. At this point I don't have much choice.
Old Jan 9, 2013 | 09:21 AM
Big Steve's Avatar
Just to give you a heads up if you decide to do this, you pretty much have to take out everything inside the car including rear seat, front seats, and center console. That was the only way that I could get the headliner out without bending/destroying it. If you are just going to Dynamat it and call it a day, then all you should have to do is drop it down and just make sure you don't sit on it when putting up the Dynamat. You will have to remove all of the pillars, the dome lights and the grip handles.
Old Jan 9, 2013 | 10:14 AM
p1llar's Avatar
Jesus that sounds like a pita. Did you drop your headliner due to a rattle or ?
Old Jan 9, 2013 | 06:47 PM
Slee256's Avatar
Maybe see if an exhaust shop can do something for you to change the resonance of the exhaust like welding in a resonator or something like that before you go tearing apart the interior.....that's my opinion anyway.
Old Jan 10, 2013 | 09:40 AM
p1llar's Avatar
I do not think it has to do with the volume of my new exhaust. The Magnaflow seems to be quiter than the DC Sports. The rattle/vibration seems to get worse as it gets colder out, when it's -15 or colder it constantly vibrates
Old Jan 10, 2013 | 11:35 AM
Big Steve's Avatar
It was an absolute pain, but I am completely happy with the results. I dropped it because I had it wrapped in black suede. While I had it out, I figured I might as well line the roof with Dynamat which helped improve the overall sound inside the car.
Old Jan 10, 2013 | 04:13 PM
Slee256's Avatar
Re-read my post! I never said anything about the "volume". I'm talking about the resonance/frequency of the sound waves that might be changed slightly with the addition of a resonator in the exhaust, and it might just be enough to stop the vibration of the interior plastics.
Old Feb 7, 2013 | 03:07 PM
clayt006's Avatar
I had the same problem. I dynamatted my light housing and everything around it. Problem solved.
Old Feb 7, 2013 | 05:02 PM
mysticf4c3's Avatar
Mine is 100% stock and the roof liner rattles only when the moonroof sun shade is open
XK120
Sep 17, 2021 10:06 AM
fafaforza
Evo X How Tos / Installations
11
Apr 10, 2017 06:17 PM
luvboost
Oct 8, 2015 06:04 AM
robertnorman06
May 16, 2011 06:35 AM
