Help with Nav
Old Aug 25, 2009 | 04:37 PM
RednekRalliart's Avatar
Help with Nav
I was wondering if any of you guys knew where the safty to keep from watching DVD's while car is running is? and how i can go around it so i can play movies while my car is on... K thx
Old Aug 25, 2009 | 05:25 PM
velocityhead's Avatar
http://tinyurl.com/kkwnue
It's been done.
Old Aug 25, 2009 | 05:56 PM
I cant find an exact thread for the answer. do you have an exact link?
Old Aug 25, 2009 | 07:12 PM
http://www.mitsubishi-forums.com/ind...pic=30744&st=0
Will have to download/burn a cd to load some different modified software, but people here have confirmed it working.
http://www.mitsubishiforum.com/forum...ad.php?t=20529
Installing a switch to trick the unit into thinking the parking brake is on.
Both methods appear to work.
Old Aug 26, 2009 | 04:19 PM
Thank you very much. this is the information i was loooking for.
Old Jan 2, 2010 | 01:27 PM
lancera's Avatar
i really want a aftermarket nav
Old Aug 6, 2010 | 09:01 AM
Ralliheart's Avatar
With my Panasonic unit when it was installed in my old Impreza, I just put the handbrake wire on a screw under the cupholder/handbrake area. This grounds the wire, which is basically what's happening when you pull up on the handbrake. On mine you can actually check the install status and it'll tell you if the handbrake is on.
-Ralliheart
nor11384
Apr 2, 2017 03:52 PM
ohmohm
Sep 30, 2015 08:23 PM
Will424
Aug 8, 2015 08:14 PM
3011carlos
Jul 18, 2013 02:50 PM
WickedMRsiNY
Sep 17, 2010 11:35 AM
