How to: Upper/Lower IC pipes & EvoX Intercooler
Old Dec 19, 2011 | 03:44 PM
  #136
MTZL's Avatar
Originally Posted by BravoZero
The only special item I need is the metal pipe going to the BPV correct?
Yes.
What about if I still have the OEM RA turbo outlet pipe when using the X UICP?
It will be fine. I rock the stock outlet just fine.
Old Dec 19, 2011 | 03:46 PM
  #137
BravoZero's Avatar
Originally Posted by MTZL
Yes.
Haha, you stalking me on EvoM? First time I've seen you here. You're always on ClubRA.
Old Dec 19, 2011 | 04:01 PM
  #138
MTZL's Avatar
I've always been here. Stalking, silently.
Old Dec 20, 2011 | 07:24 AM
  #139
Slyy's Avatar
Question... I have the full X intercooler, piping and clamps and I'm going to be installing this soon.
You don't have to do that pipe mod for the BOV to the LICP. You can use your stock hose; but it will be very tight.
One more option you can do, is go to your local auto shop and bring in your BOV and test fit Radiator hoses and see which one fits. Find one that has a curve that would bend at the battery location.
Bring it home and cut the hose to fit.
That's what i did.
Your RA outlet pipe will be fine with the X UICP. Just tighten it good.
Old Dec 20, 2011 | 07:25 AM
  #140
BravoZero's Avatar
Awesome, thanks folks.
Old Jan 7, 2012 | 04:58 AM
  #141
Steven_Trujillo's Avatar
Hey if anyone is going to try this mod out and have any trouble putting any of the piping on try some vaseline. Not too much just a super light coat and it should just slide right in LOL
Old Jan 9, 2012 | 11:57 AM
  #142
Veronica's Avatar
^even better is to use dish soap. Slicks it up to ease install and then drys sticky
Old Jan 16, 2012 | 10:23 AM
  #143
pixius143's Avatar
We just did the stock to Evo X IC swap this weekend. Took most of the day with those "invisible" bolts. We bought a 6"x 1-1/2 piece of drain pipe and used Mopar lube to squeeze it on. Worked pretty flawlessly. DEFINITELY notice the difference in response! Thanks for the help!
Old Jan 17, 2012 | 08:06 AM
  #144
BravoZero's Avatar
OP... The link you provided for the beaded drain pipe only has 3" long pipes, not 6". Maybe they updated their site since your thread was created?
Old Jan 18, 2012 | 01:20 PM
  #145
pixius143's Avatar
Its all the same, really. The piece of pipe we bought was 6" x 1-1/2 and it had threading on the ends, so its grabbing the rubber like it should. It works perfectly as a permanent piece, especially since you're tightening it down. That will save you a lot of time and money. At the same time, I also plastidipped the black vents on the hood. Looks great.
Old Feb 10, 2012 | 02:25 PM
  #146
markspd6's Avatar
this is my next day off project.. as soon as i find a nice cheap licp..
Old Feb 11, 2012 | 04:05 PM
  #147
import_racing's Avatar
Anybody knows where i can get the 6in pipe? The website doesnt offer 6in anymore just the 3in pipe.
Old Feb 11, 2012 | 05:20 PM
  #148
BravoZero's Avatar
Read through this thread... there are plenty of alternatives. Search.
I'll give you a hint... Home Depot or Lowes in the plumbing department.
Old Feb 11, 2012 | 06:03 PM
  #149
Lol thanks a lot bro!!
I hope they have the Double Beaded Hose. =D
Old Feb 12, 2012 | 03:28 PM
  #150
markspd6's Avatar
for my last turbo car, i just went to pep boys and made em take out random OEM radiator hose til one worked.. it was easy.. and like $12..
