How to: Upper/Lower IC pipes & EvoX Intercooler
Old May 16, 2011 | 03:25 AM
  #106
03chi-town0Z's Avatar
64mm diameter, about 150mm long
Old May 16, 2011 | 10:06 AM
  #107
tdotsnipe91's Avatar
how bigs the opening on the evo x fmic and the stock ra licp?
Old May 17, 2011 | 12:47 PM
  #108
EvoOtto's Avatar
Just so I understand correctly. We need a 6" coupler that's has a 2.5" diameter correct? Then the RA lower I/C pipe will work with the Evo intercoolers?
Old May 17, 2011 | 01:41 PM
  #109
Correct. EvoX FMIC outlet is 2.5" diameter, Ralliart LICP inlet is 2.5" diameter.
Ralliart FMIC outlet is like 2.25" diameter, if you look at the stock coupler it has a slightly reduced section on the FMIC side, this is why you need a new coupler for the Evo-based FMIC's
Old May 17, 2011 | 02:22 PM
  #110
thanks for the help been looking for this answer for a bit lol
Old May 17, 2011 | 02:45 PM
  #111
EvoOtto's Avatar
Me too. Used the search but never gave me the answer I needed. Didn't want to get flamed so I just kept looking. LOL
Old May 18, 2011 | 08:53 PM
  #112
RalliMark's Avatar
I think a 6 in couplers gonna be to long on the licp I tihnk mines like 4 tops maybe 3
Old May 19, 2011 | 03:37 AM
  #113
You may need to trim at 6", but its always better to buy a longer piece and cut it shorter. Plus I personally prefer to have a little extra coupler behind the clamp area, just for peace-of-mind that it won't blow off the firsst time I wot, more a mental thing than anything probably.
Old Aug 21, 2011 | 02:33 PM
  #114
Jechttt's Avatar
Done and done. My 6inch bov connector kept coming off in any boost, finally got it to stay put.
I may order the ribbed pipe and get it done right, I used electical tape on a 6in nipple piece from HomeDepot, 1inch Inside diameter.... if it comes off again I will order that piece.
Overall A fun experience, just wish any luck to people with huge hands....
I have tiny hands so I was good to go for the most part. Since I've been worried about blowing the damn connector I never went full throttle, I'll update soon. Otherwise quicker throttle response for sure, fun project, thanks for the write up!
Old Aug 22, 2011 | 09:41 AM
  #115
velocityhead's Avatar
No problem, glad it was helpful. And yes, getting the correct type of tubing is very worthwhile.
Old Aug 26, 2011 | 02:40 PM
  #116
Jechttt's Avatar
Well I must say it drives differently.. better or equal I am still not sure. Its still gets up to speed fast, its more solid, less jerking for sure, can't put my finger on it. after about 30% throttle and after 4kRPM I don't feel a significant acceleration with more throttle. I'll log it later, maybe tomorrow.
Old Sep 8, 2011 | 11:27 PM
  #117
matizzay's Avatar
Where is the best place to get strong couplers? I've been told not to trust ones from home depot as they will not handle the pressure. Any exp with this?
Old Sep 9, 2011 | 06:46 AM
  #118
Slyy's Avatar
Go to a performance shop. Like Performance improvement or next mod etc.
Don't get home depot stuff.
Old Oct 4, 2011 | 12:23 PM
  #119
Chaz17's Avatar
wait are we going to need that 1.5" pipe you posted? i bought a UR uicp/licp and evo x intercooler... i understand basically what to do but what extra parts do i need and what little surprises are there going to be?
Old Oct 9, 2011 | 08:30 AM
  #120
RalliMark's Avatar
Everything should have come from UR. Id suggest getting some t-bolts instead of those crappy worm clamps.
Matizzay Xtreme psi sells all the couplers ull need.
