How to: Upper/Lower IC pipes & EvoX Intercooler
it should go on easily with a tiny gap sticking up, most likely u didnt push the uicp down onto the fmic far enough which is what happened to me the first time when the plastic didnt fit.
Rallimark, I and a couple other people have had to file or cut a little bit of that plastic piece. you should see or feel a small lip on the under side and that can be filed down to make it sit flush again.
Even with the UICP elbow fully seated against the EvoX FMIC in my car it was still "too high" to allow my hood to fit properly. I ended up shaving off about 1/8" from the the bottom part of my UR UICP elbow (just the straight section below the bead). Once I did that, I was finally able to close my hood and have it sit evenly all the way across the front like it should.
Out of curiosity, I have a question:
Those of you with the UR UICP and an EvoX FMIC with NO fitment problems, did you install the EvoX FMIC using side hangers AND the two bottom bolts? Or did you only use the side hangers W/O the 2 bottom bolts when you installed your EvoX FMIC?
Oh yeah and there were no fitment issues with the radiator cover not sitting flush. I had that issue before I switched to the evox fmic but now that the swap is done everything fits like it should. So I am assuming that if there is a gap, then you most likely need to push the piping down further.
Yeah, you would think so, and I would think that as well if I didn't have the problem. However, with my car and the UR UICP that I received, even with the UICP pushed down so far that it makes full contact with the EvoX FMIC the elbow still sat too high. I actually had to trim 1/8" from the FMIC end of my UR UICP (in addition to shaving the ribs on the back side of the panel) in order to make it short enough to allow everything to fit properly.
