RFI: Battery Relocation Fuse Position
Old Jan 9, 2012 | 05:36 PM
ra_guy's Avatar
So I successfully completed a battery relocation, but i'm not quite satisfied with the location of the main fuse. What have those of you that have relocated the bat to the trunk done with this? Right now mine's sort of "hanging" under my X intake...
Old Jan 10, 2012 | 10:47 AM
Veronica's Avatar
The fuse must be close to the battery to be the most effective (i.e. sense and open the circuit in case of a short in the battery cable). All the POS bat cable between the battery and the fuse is 'unprotected'. badbadbadbadbad....
Old Jan 10, 2012 | 10:52 AM
Vivid Racing's Avatar
Wait, your fuse is in the engine compartment but the battery is in the trunk? You need the fuse to be withing 18" (I never go more than 6" ) from the battery.
Old Jan 11, 2012 | 04:44 AM
ra_guy's Avatar
The main cable from trunk to engine compartment is protected by a DC circuit breaker ATM. What I'm asking about is relocating the factory fuse located under the red plastic cover...
Old Jan 11, 2012 | 06:08 PM
richardjh's Avatar
The distribution block thingy?
Check out the myriad Evo X engine bay images around for ideas. IIRC, theirs is positioned near/off the upper ECU fitment bracket, doesn't it?
Rich
Old Feb 2, 2012 | 08:09 PM
cky_2k's Avatar
Fuse 12" from battery..... Don't want to take any chances
KenyonKanye
Oct 2, 2016 05:20 PM
Luckiesralliart
Nov 29, 2012 09:51 AM
bigric09
Jan 20, 2008 05:14 PM
joeymia
12
Jan 23, 2006 09:22 PM
w2pac12345
Oct 14, 2003 08:43 AM
