Why does the car keep running after pulling the alternator fuse
Old Jan 23, 2006 | 08:24 PM
joeymia's Avatar
Since I have a relocated battery in the trunk, I have to use a battery cut off switch. To get this working correctly you need to have the alternator disconnected. I have pulled the fuse out and I got the alternator light on my dash but the car keeps on running. The switch works fine If I disconnect the positive cable off the alternator but I would rather just pull a fuse. I would really love to have a swith inside the cabin of the car if its possible as well. Is there a secondary fuse somewhere? Does someone have a alternator cut off inside the cabin?
Old Jan 23, 2006 | 08:26 PM
BoostWhore's Avatar
why dont you just use a switch to kill the power to the battery
Old Jan 23, 2006 | 08:29 PM
TEXSRT4's Avatar
no it is running off the battery when you disconnect the alternator. if the battery was disconnected and you pulled the fuse everything would die
joeymia's Avatar
if you kill the battery with the alternator connected the car keeps running.
Old Jan 23, 2006 | 08:30 PM
joeymia's Avatar
with the battery switch on the off position and pulling the alternator fuse the car keeps running I have never seen a car do this its just odd.
Old Jan 23, 2006 | 08:31 PM
WHTEVO's Avatar
The car doesn't NEED the alternator to stay running. It is drawing power from your battery for things such as the ECU and whatnot. You can always do what the person above stated. Why would you want to disconnect your alternator? Good luck.
Old Jan 23, 2006 | 08:35 PM
JTB's Avatar
JTB
If you do buy a cutoff switch, make sure you get one with circuitry to save your alternator (usually some kind of capacitor). Shutting down the engine with just an on/off switch on teh battery leaves the alternator nowhere to dispose of the charge it would generate as the engine comes to a stop and you end up with a fried alternator.
What exactly are you looking to gain by adding this switch?
Old Jan 23, 2006 | 08:38 PM
4WS Tuning's Avatar
the alternator just charges the battery...im sure itll die eventually....just leave it running, when the battery dies the car will turn off
cheers
if u want the car to turn off with the flip of a switch connect it to the engine management or ignition
Old Jan 23, 2006 | 08:45 PM
4WS Tuning's Avatar
i dont get y u need a switch to turn it off? all you did was extend the positive wire to the trunk and find a new ground....the system didn't change, y do u need a switch?
Old Jan 23, 2006 | 08:52 PM
SaOrlando's Avatar
get a battery isolator. the relay on it hook to a switch, hook up alternator turn on/off to same switch, when you flip off they both shut off. u can buy a isolator(very large relay) for about 15-20.
good question, why the switch?
Old Jan 23, 2006 | 09:05 PM
joeymia's Avatar
Those are the rules at Moroso, they require the car to turn off instantly with the flip of the cutoff. They are very strict with the rules. I also need to get a new battery box because they don't allow a plastic one For now I have the cutoff switch behind the passenger side tail light. When I go to tech I just disconnect the postive cable off the alternator. When they flip the switch the car turns off. I just don't understand why pulling the fuse doesn't work.
Old Jan 23, 2006 | 09:16 PM
4WS Tuning's Avatar
ya moroso is gay...i hate going there, i would just hook a switch up to the engine management fuse, i accidentally pulled it out once when i was pulling out a different fuse and it turned my car off...there is some1 selling a trunk kit right now for 90$ i think...looks clean...check it out in the private sales
cheers
Old Jan 23, 2006 | 09:22 PM
joeymia's Avatar
cheers
That is the closest track to Miami When they built the Homestead Race Track they promised a 1/4 mile track. Of course it never happened. I guess building more houses was more important. I can't wait till they shutdown the smaller events there because of "noise". For now I gotta drive for about an hour and told I can't race because my battery box is plastic
overdrive1
Jun 1, 2022 08:54 AM
Headhunterz1105
Aug 9, 2016 03:01 PM
403evo
23
Dec 16, 2015 04:41 PM
RalliartN
Nov 2, 2015 08:57 AM
keath
Aug 18, 2010 08:01 AM
