New Bolt in turbo... FP White Rabbit.
Old Jun 21, 2005 | 10:54 AM
  #451
Fenris Ulf's Avatar
Originally Posted by nickracer9
what did the car make corrected power?
Finally an intelligent dyno interpreter on the boards!!
I too would like to see an SAE corrected sheet, uncorrected numbers mean NOTHING.
  #452
TurboTodd's Avatar
White Rabbit
The White Rabbit Turbo has been on my car for over a month now. It has performed flawlessly. I am using a flash by the WORKS with the AFC as a piggy back. My mods are…Automotosports full exhaust, O2 housing, front mount w/lower intercooler pipe, AEM intake, GFB blow off valve, HKS 264 cams, WORKS Throttle body, HKS Twin Power Ign. Magnecor wires, NGK bpr7es plugs, Snow Performance water/alcohol custom 2stge kit. 91 octane is all that’s ever been in the tank. I hope I haven’t forgotten any mods.
Current boost level is a 27lbs spike falling off a little. I will have dyno numbers soon. I can say that this turbo made a substantial power increase over stock and spools very fast. A friend of mine with a 02 ZO6 checked out some EVO tail lights the other day. This is the only power example I have for now. I’ll check back soon!!!
Old Jun 21, 2005 | 11:01 AM
  #453
marksae's Avatar
Damn, 27 psi on 91 octane!
BTW, are you the same Todd that had the 10 sec red 1g a few years back?
Old Jun 21, 2005 | 11:05 AM
  #454
Erik@MIL.SPEC's Avatar
Do you have head studs running that high of a spike? Thanks.
Old Jun 21, 2005 | 11:55 AM
  #455
954DRGSR's Avatar
That is a little high on pump.
Old Jun 21, 2005 | 11:59 AM
  #456
He's running alcohol/water injection.
Old Jun 21, 2005 | 12:09 PM
  #457
Ludikraut's Avatar
Just multiply the uncorrected number by your favorite correction number ... and presto!! ... you have your "corrected" sheet. IMO correction factors are just as silly as trying to compare dyno numbers from different dynos. I'll take uncorrected numbers any day of the week.
l8r)
Old Jun 21, 2005 | 12:20 PM
  #458
lexat20's Avatar
Originally Posted by atlvalet
No bb center section. It's not really needed.
Can you elaborate on this?
Old Jun 21, 2005 | 12:21 PM
  #459
NYREDEVO's Avatar
l8r)
Does anyone know what that car put down before the rabbit was put on the car? On that dyno?
Old Jun 21, 2005 | 12:27 PM
  #460
It spools like stock. If you want a bb section stock-like turbo, put on the UK400 turbo. The only thing is, with the £ the way it is, it costs like $3000 USD.
Old Jun 21, 2005 | 12:32 PM
  #461
Vapor's Avatar
as a dyno tuner of 7 years, i can tell you that correction factor is not accurate when it comes to forced induction vehicles.
A good article related to the subject by some guys in the biz of tuning
http://www.sdsefi.com/techdyno.htm
Old Jun 21, 2005 | 12:34 PM
  #462
lexat20's Avatar
What is the diff exactly. I know one has bb the other doesn't but what are the pros/cons. Thx for help by the way.
Old Jun 21, 2005 | 12:42 PM
  #463
thatsMR2u's Avatar
does turbo come polished? and is there any option to port it
Old Jun 21, 2005 | 12:43 PM
  #464
PPI's Avatar
PPI
does anyone know what lb. compressor this turbo uses?
Old Jun 21, 2005 | 12:55 PM
  #465
Jamie@WORKS's Avatar
I bet he's the same Todd you're thinking of
