Turbo purchase gone bad…need advice
Old May 23, 2007 | 07:45 PM
  #76
Jim in Tucson's Avatar
Originally Posted by Jedi_Gill
[B]
Both parties communicate to end any bad blood between them, and the solution would be to have the turbo repaired. Both the seller and the buyer should split the cost for the repairs. The installation shop should be kind enough to give the buyer a discount for installing the 2nd turbo for good faith that they are willing to understand these situations and help out the customer.
1. In the end the seller loses a bit of money but feels a bit better that a compromise was found.
2. The buyer reduces his costs, and ends up with a rebuilt turbo that he can sell to further reduce his costs.
3. The shop reduces the labor for the 2nd install, and shows it's commitment to human understanding of this situation. The reinforce their commitment to good customer service even though they may or many not have been at blame.
And everyone is happy..
Very thoughtful post, Jedi. Have you ever considered work as an arbitrator or mediator?
In my PM to the seller I simply asked them to offer a solution. Their silence on a solution can only point to their apparent conviction that I am solely responsible here. I don't think they are interested in a middle ground, so to speak.
They obviously have a large fan club. On the other hand, I've not had a single one of my friends come on this thread and tell what a great guy I am. I've attempted to keep the focus on the turbo. That is what I bought - a turbo.
I did examine the turbo sufficiently to conclude that it looked great. As Gabe stated, iA Performance examined the turbo before install. There were no indications of any problems with the turbo. I'm not actually sure how the coolant manages to leak into the exhaust, but obviously it is not an external leak as there were no visible leaks when the car and turbo were running. There was only the white cloud of superheated coolant indicating some kind of internal leak within the turbo.
Thanks again for the effort you put into your response.
Old May 23, 2007 | 07:55 PM
  #77
CO_VR4's Avatar
Cut to the chase.
Have the turbo torn down and find the problem. If it's cracked, which seems likely if you have coolant in the exhaust and exhaust in the coolant, that's not caused by an installation, or by not prelubing, etc. etc. etc.
Not much use in having continued speculation until you have a diagnosis.
Old May 23, 2007 | 08:01 PM
  #78
fromWRXtoEVO's Avatar
^^ I totally concur with you. I maintain that the turbo was perhaps partially clogged with something during transportation. Before speculating I would definately open the turbo and have it recheck.
I am giving positive feedback on the shop and the crew that did the installation and I am also giving positive feedback on the seller.
I am inclined to believe that the turbo was mechanically compromised during the shipping.
Carlos
Old May 23, 2007 | 08:33 PM
  #79
MalibuJack's Avatar
Without taking sides, this is the downside of buying used parts..
Regardless of the reputation of the buyer and seller, parts are generally sold "as is, with no explicit or implied warranty" Nobody is really required to make things right, but retailers of used and new parts do these things as a courtesy. Obviously things are different if the parts are sold knowingly defective. This doesn't appear to be the case.
I have had both good and bad experiences selling and buying parts online, in many cases there isn't much you can do if your buying from an individual who didn't knowingly sell a bad part.
In any case, none of the parties will be able to adequately prove they weren't at fault, and enough time had passed that makes things even worse.
If I were the seller, I would do my best to make things right, but I don't think its right for the buyer to expect a full refund.
Old May 23, 2007 | 08:37 PM
  #80
belizelittle39439's Avatar
The "fan club" wouldn't appear if you didn't try and drag someone's reputation down because of botched install. Long story short--it worked fine beforehand with many witnesses that can attest to it. Smoked after the install. Logically speaking...what's the most likely scenario here? Simple logic: If it didn't smoke before--it's not going to miraculously smoke upon install either unless someone dropped it, or screwed up the install. Why is that so hard to understand?
The best thing would have been to keep this private since it was no one else's business but yours and Tony's. You made the mistake of airing your dirty laundry and didn't expect that there would be so many witness's to discount your accusations.
However...I do agree that you should have the turbo dismantled and looked at. I also agree that you should probably just have it rebuilt into a green.
Old May 23, 2007 | 08:50 PM
  #81
CO_VR4's Avatar
Just for our education, please detail the mistake in a turbo installation by the shop that you surmise caused a crack in the CHRA that would result in allowing exhaust in the coolant and coolant in the exhaust. I'd love to know, so I can make sure to avoid it the next time I swap a turbo. Guess the last 20 or so I swapped I was just lucky...
As far as dropping it, disassembly will tell the story. I'd guess, though, that it would take some special skill to drop a turbo so as to cause a crack in the center section and show no evidence of it anywhere on the exterior...
Old May 23, 2007 | 09:15 PM
  #82
4G63's Avatar
Originally Posted by IA Performance
Our policy on installing used parts that are not bought through us is very strict we are not liable for parts that may or may not work unless we provide them, such as the Turbo that is on Jims car now. When our tech examined the turbo you could see a greyish film which possibly indicates prior smoking, so the turbo may hav been on its way out before Jim got it, but this doesnt mean the owner of the turbo knew it either I believe there may have been a small leak in it before it came to us and I hate to say the shipping companies that we use im sure arent the most cautious with packages (you remember that scene from Ace Ventura)so it probably got thrown around a few times I hope this can be sorted out. For the orignal owners if you have any questions on our install feel free to PM me or give us a call we will be more than happy help out however we can
Once again I will quote this. Does anyone else see a problem here? Why was this turbo installed if it was possibly screwed up? Was the owner notified that it was possibly damaged? If he was and decided to install it anyway, then screw him its his loss! If he wasn't notified and it was installed, then the shop bears some responsibility here. Even though IA stated they don't warrant used parts that they didn't procure, someone should have notified the buyer that there was possible turbo damage. If this had happened then 'Jim' would have had a claim of damage against 'Tony'. IMO, one way or another IA has a hand in this dispute and isn't speaking up!!
Old May 23, 2007 | 09:40 PM
  #83
I'm not going to bother...how is it that hard to understand? Afterall...you've done 20 right?
Old May 23, 2007 | 10:09 PM
  #84
Honestly...this thread needs to be closed right here and now. It provides no helpful resource between either the seller or the buyer, and has resorted to theory and conjecture. The horse is dead--let's stop beating it.
Everyone seems to know more than everyone else...and people who aren't involved in any way are chiming in like parrots repeating the same information over and over.
So mods...I'm sure you've seen this....its never going to end without someone ending it.
Old May 23, 2007 | 10:14 PM
  #85
EJEvo's Avatar
When our tech examined the turbo you could see a greyish film which possibly indicates prior smoking, so the turbo may have been on its way out before Jim got it...
To me, this is the key detail here. The question I have is, when did this inspection take place and condition noted? Was it before the install, or after?
Old May 23, 2007 | 10:45 PM
  #86
Pah-leeze read the thread from the beginning, Mr. Evo. I did not mention the sellers. They came into my thread and outed themselves. I simply described a transaction and was seeking advice from more experienced members.
Old May 23, 2007 | 11:00 PM
  #87
SASD209's Avatar
Admin Alumni
CLOSED pending review by EvoM staff...///
J.D.
CmakEVOX
Member Unresolved Disputes
34
Feb 2, 2014 07:24 PM
bsh
12
Apr 9, 2013 05:41 AM
xTiCkxMYxLaInTx
14
Dec 26, 2012 09:17 AM
jjm4life
54
Apr 12, 2009 08:48 PM
recompile
24
Apr 1, 2007 08:40 AM
