All Part Number Request Go Here
Old Jun 4, 2008 | 09:11 PM
  #2566
esevo's Avatar
I cant find the part number to the OIL LINE that goes from the block to the head for the MIVEC. Anybody know the #??? Thanks!!!
Old Jun 9, 2008 | 02:47 PM
  #2567
ride switch's Avatar
im lookin for the outer bolts on the valve cover (the black ones not the gold ones) and the cap for the center diff fluid reservoir (evo IX). thanks in advance
Old Jun 10, 2008 | 12:46 PM
  #2568
Spins4's Avatar
1028A044
Old Jun 10, 2008 | 12:49 PM
  #2569
Spins4's Avatar
MF245428 for the bolts and MR580135 for the cap.
Old Jun 10, 2008 | 01:00 PM
  #2570
justchil's Avatar
Originally Posted by justchil
Green in this pic:
Still looking... if it's the entire endlink that's fine too... I need to check for aftermarket solutions as well.
Old Jun 10, 2008 | 01:15 PM
  #2571
Spins4's Avatar
Originally Posted by LetsGo82nd
Tried searching for the part numbers in the thread but I may have been using the wrong keywords. The bolts/washers I need are for:
Bolts/washers that attach the Air Outlet Fitting to the Turbo.
Bolts/washers that attach the Oil Return Line to the Turbo and to the Oil Pan.
Thanks for the help.
Bolts to outlet pipe (no washers) : MF241253
Bolts for return line to pan : MN156739
Washers for above : MR497720
Old Jun 10, 2008 | 01:19 PM
  #2572
Spins4's Avatar
MB616023 ....cheap ...only like $7 and change...and if you want the whole tie rod end for the heck of it, the part # is 4422A002 ...
Old Jun 11, 2008 | 06:01 AM
  #2573
LetsGo82nd's Avatar
Thanks very much for the help with this.
Old Jun 11, 2008 | 12:46 PM
  #2574
Spins4's Avatar
No prob!
Old Jun 11, 2008 | 06:30 PM
  #2575
EvoDan2004's Avatar
i need the part number for the rear ball joints. if your looking at the hub and suspension setup at eye level its the center left one. i need driver and passenger. thanks.
Old Jun 12, 2008 | 01:33 PM
  #2576
EvoDan2004's Avatar
bump
Old Jun 14, 2008 | 07:00 AM
  #2577
dapaspy's Avatar
Need this part number urgently
Old Jun 14, 2008 | 12:24 PM
  #2578
Raistlin's Avatar
I am looking for the part number for the center dome light on a VIII.
This is what it looks like before you take off the cover.
What I need is the grey plastic piece and the copper connector on the left hand side.
As pictured here.
This was broken when I got the car. I will need both the plastic piece and the wire that has the copper end that connects to the bulb since both are broken.
Thanks
Raist
Old Jun 14, 2008 | 12:27 PM
  #2579
mmartahus's Avatar
part number for a US version lancer 08-09 DE front grill?
Part number for heated seats switches for canadian version lancer 08-09
Old Jun 15, 2008 | 01:51 PM
  #2580
mini_evo's Avatar
I tried searching for the P/N's with no results..... I am looking for the P/N's for the EVO 9 SSL, MR, and SE front lip. when I had my car shipped, The company Fncked my **** UP!!!!
TIA, mini_evo
