What is the max load are u seeing guys?
Old Jan 3, 2009 | 01:09 PM
  #106
cossie1's Avatar
Both Roms report 2ba1 for me.
Nice work John, guess I need a GT35R now lol
Old Jan 3, 2009 | 02:51 PM
  #107
Ted B's Avatar
Originally Posted by jcsbanks
Excellent, glad it works.
Ted, 94170008/94170015:
<table name="Set to 9 to remove load limit" address="26592" type="1D" level="1" scaling="Hex16"/>
Thank you!
Old Jan 3, 2009 | 11:49 PM
  #108
KevOVIII's Avatar
Nice! Do you have this for 96530006?
Thanks in advance.
Old Jan 4, 2009 | 03:49 AM
  #109
jcsbanks's Avatar
96530006:
<table name="Set to 9 to remove load limit" address="27824" type="1D" level="1" scaling="Hex16"/>
Old Jan 4, 2009 | 05:51 AM
  #110
Darwinn's Avatar
88840017 please ?
Old Jan 4, 2009 | 07:29 AM
  #111
jcsbanks's Avatar
88840017:
<table name="Set to 9 to remove load limit" address="2901a" type="1D" level="1" scaling="Hex16"/>
Now I must turn my attention to some other MAF stuff, more requests for ECUs only if you are smashing against the 380 load limit please
Old Jan 4, 2009 | 10:24 AM
  #112
psphinx81's Avatar
so all i do is add this line to my ROM and im set?
Old Jan 4, 2009 | 10:26 AM
  #113
Ted B's Avatar
Almost . . .
You will reset the lone value to "0009" by typing "0x9".
Old Jan 4, 2009 | 10:32 AM
  #114
psphinx81's Avatar
yea i did that as well, thanks!
Old Jan 4, 2009 | 03:59 PM
  #115
JohnBradley's Avatar
Hmmm well it is cool that this was cracked. I havent got a chance to retest it but it seems to be irrelevant now since this is a simpler solution. I must have been seeing reporting errors so I will withdraw my claims.
Old Jan 5, 2009 | 12:23 AM
  #116
KevOVIII's Avatar
96530006:
Thank you! Confirmed that it was 2ba1.
Now to schedule a dyno session with Bryan and let him tune E85 plus meth injection.
Old Jan 26, 2009 | 02:27 PM
  #117
jcsbanks's Avatar
Mellon, for 96940011, try adding this to your xml and change the value from "2ba1" to "0x9".
<table name="Set to 9 to remove load limit" address="28140" type="1D" level="1" scaling="Hex16"/>
I hope this allows higher than 380 load, pls check for normal behaviour, and that it registers the correct fuelling and timing from your maps though as there could be other limits or overflows in there.
I would just put the earlier tables I mentioned back to stock, no longer necessary, this disables their effect anyway.
Mellon, I've looked more into this. What you've done has unlocked the load limit. However, the IPW is calculated by multiplying the fuel map lookup value (AFRMAP) by another variable that also needs to be unlocked:
<table name="Set to 9 to remove fuel limit" address="282C6" type="1D" level="1" scaling="Hex16"/>
Original value will again be 2ba1, change to 9 as before.
If you are just kissing the 380 load limit, this will make no difference. If you are at 400 load then I would expect this would give you about 5% extra IPW. Without this change you would need to richen the fuel map zones over 380 progressively to keep the same AFR (assuming all else is equal such as fuel flow, MAF sensor calibration etc).
I think you should be good to go to the flow or electronic limits of the MAF sensor now, and I do not forsee any weirdness or overflows.
Please apply the new changes and let us know how you get on
Old Jan 27, 2009 | 12:27 AM
  #118
KevOVIII's Avatar
May I have the 96530006 address please?
Old Jan 27, 2009 | 08:05 AM
  #119
Ted B's Avatar
And for 94170015 as well please!
Old Jan 27, 2009 | 09:39 AM
  #120
Mellon Racing's Avatar
thanks jcsbanks, I don't know how quickly I can test the new settings, I'm extremely busy lately.
