94170715 V7 Issues
Old Apr 5, 2010 | 12:14 PM
  #61
Boosted Tuning's Avatar
Originally Posted by chmodlf
What you are logging is the 2 bytes (RPM, Load, Airflow). This is different from what Tephra put in his v7 roms 9653 and 94170715. Remember MUT logs what you the end user wants. There are no "wrong" answers here. MUT is only logging parameters not changing the way the code itself works. 2 byte RPM is unnecessary. 2 byte load can also be replaced by 1 byte which is in some sense a more efficient way of logging load. My only advice is to be careful which MUT addresses you overwrite.
BTW Some of my MUT requests are logging different compensated loads (temp, and baro and temp) which depending on which rom are used rather than the uncompensated or raw load.
Not if you rev higher the 7968rpm.
Old Apr 6, 2010 | 05:00 PM
  #62
chmodlf's Avatar
Sounds like you are having some fun
Old Apr 7, 2010 | 03:17 AM
  #63
tephra's Avatar
yeah but you probably wont be reving much higher and you can always manually calculate the rpm since the 1byte will loop over... so just add 7968 to it
logging stuff thats not worthwhile really isn't worth it
Old Apr 7, 2010 | 05:59 PM
  #64
tephra's Avatar
ok EvoKid told me apparently there is a problem with 94170715 V7...
Can someone give me a run down again? its been a long time
Old Apr 7, 2010 | 06:11 PM
  #65
ace33joe's Avatar
First of all, I appreciate your efforts for providing these awesome mods! Regardless of these minor issues, I love the V7 roms!
I am willing to help you resolving the minor problems, if there is something I can do.
So far I noticed gear, RPM_SPEED_RATIO_AVG, and boost error (when using psi based boost control) are not logging right, and I think related functions are not working fully yet.
Old Apr 7, 2010 | 06:44 PM
  #66
tephra's Avatar
ok one at a time then
can you :
1) post a picture (readable) of your MUT_TABLE
2) post up the xml that you are using for gear and RPM_SPEED_RATIO_AVG
Did you use the V7 download or a pre-configured rom by phenem/applaud/whoever?
Old Apr 7, 2010 | 06:48 PM
  #67
Appauldd's Avatar
I sent him my XML. I don't know what ROM he is using. I will email it to you.
Old Apr 7, 2010 | 06:59 PM
  #68
ace33joe's Avatar
Ok, I am excited that we are now starting to attack these issues.
For the MUT table, I attached the bmp file.
For the XML, if you mean the evoscan, I used the one posted at the main Tephra Mod V7 page.
<DataListItem DataLog="Y" Color="" Display="Gear" LogReference="Gear" RequestID="40" Eval="x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="5" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="RPM_SPEED_RATIO_AVERAGE" LogReference="RPM_SPEED_RATIO_AVERAGE" RequestID="42" RequestID2="43" Eval="x/36.37" Unit="rpm/kph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
And for the XML for rom itself, I used the Appauldd's most updated one. I added a few minor stuffs, but nothing related to gear or boost.
And for the rom, I first downloaded one from the main Tephra MOD V7 page (post #1), and then I found the gear based boost is not working, so I started fresh from downloaded from post #2 of the Tephra MOD V7 page. (Phenem's pre-configured one, Option 2 (V7 + Mods Omni 4bar))
I can also email you my updated XML + rom to you if you let me know your email address. Thanks!!!
EDIT: My original post about this issue is here.
https://www.evolutionm.net/forums/8139848-post184.html
Old Apr 7, 2010 | 07:04 PM
  #69
Appauldd's Avatar
You have mail. I sent my rom and XML for your viewing pleasure.
Old Apr 7, 2010 | 07:19 PM
  #70
tephra's Avatar
ok so Gear is using MUT40...
if we look at your MUT_TABLE MUT40 refers to 0x8447 - which hopefully expands to 0xFFFF8447 (you might need to get the other MUT TABLE XML to double check this)
V7 uses 0xFFFF8446 for the gear ratio, so the 0xFFFF8447 is correct.
as long as that subroutine is being run...
RPM_SPEED_RATIO_AVG is MUT42 and MUT43.. which in your MUT_TABLE refer to 0x8448 and 0x8449
looking at my code, RPM_SPEED_RATIO_AVG is 0xFFFF8448... so again correct...
i just looked at my blank 94170715 V7 ROM and that code is being called correctly
can you please send me the ROM that you are using?
Cheers
D.
  #71
tephra's Avatar
sorry Applaud - that last post is for ace33joe
Old Apr 7, 2010 | 07:20 PM
  #72
tephra's Avatar
CRAPPPP
found the problem...
edit - can you add this to your tephramod_94170715.xml
Code:
<table name="94170715 GEAR Fix1" category="TephraMod-V7" address="3f16e" type="1D" scaling="Hex16"/>
then change 0x6a2c to 0x8a2c
then flash and report back
Old Apr 7, 2010 | 07:24 PM
  #73
ace33joe's Avatar
Ok, I cannot find your email address. If you can shoot me an email to me, I can reply to it.
ace33joe at gmail dot com
Thanks!
Old Apr 7, 2010 | 07:26 PM
  #74
ace33joe's Avatar
CRAPPPP
Code:
Ohhhhhh! I will test it tonight, and report it back! Only noon here, and I am at work! Thanks, Tephra!
Old Apr 7, 2010 | 08:01 PM
  #75
ace33joe's Avatar
I am pleased that this rom is available so no bad kharma.
I also noticed that the Max WGDC vs coolant temp address is off in appauldd's xml. Anyone know the correct address? It is currently 56D2.
Ok, one more here.
Max WGDC vs. Coolant temp table looks weird as attached.
Thanks!
