Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old Jun 6, 2010 | 10:59 PM
  #496
RoadSpike's Avatar
Originally Posted by link62
hmm ok well im not sure what to do now to get the start ups better cause im not sure if the changes to the enrichment did anything cause i still got to push on the pedal to start it
I'll email tephra to be sure for you guys see if there was anything i'm missing here
Old Jun 7, 2010 | 12:45 PM
  #497
bvasquez12's Avatar
Okay on the maf scaling i notice a few values that i cant copy over from the eclipse rom to the lancer rom.
The lancer table is on the right for scaling and smoothing. Is there a way i can change the load values to match the eclipse roms also how do i increase the values on the right by .xx instead of increments of 1.
Old Jun 7, 2010 | 01:30 PM
  #498
RoadSpike's Avatar
The scaling is different.
Also it appears that the left hand column isn't located to the correct address.
Old Jun 7, 2010 | 03:16 PM
  #499
bvasquez12's Avatar
So how can I fix this, do I need to find my Own values, or should I go back to the evo rom.
Old Jun 7, 2010 | 03:49 PM
  #500
RoadSpike's Avatar
Right click the table and see what the scaling is and make them both the same. You could use unit8 if you can't find one scaling or the other.
As for the left hand column I'd just leave it alone probably doesn't have the right address in there anyways.
Old Jun 7, 2010 | 04:18 PM
  #501
bvasquez12's Avatar
what if one tablegoes to 7000rpm and the one on the lancer rom only goes to 5250. Do i need to find the values on my own, like just keep trying it until i find what works best??
Old Jun 7, 2010 | 04:33 PM
  #502
RoadSpike's Avatar
Obviously a direct copy wont work if the scaling is different as the values where the scale equals the same wont match up. I'm assuming this has something to do with fuel or timing?
Old Jun 7, 2010 | 05:49 PM
  #503
bvasquez12's Avatar
okay i think i got pretty much everything worked out for the most part, only thing i notice is that my rpms drop a little slowly after i go from say a 3rd gear pull to coasting in nuetral.,
Old Jun 8, 2010 | 09:20 AM
  #504
RoadSpike's Avatar
Update.
Confirmed that the rom itself doesn't have a way to disable cranking enrichment thanks to tephra and mrfred. I also noticed when comparing it to another rom that my definition for cranking ipw enrichment is likely wrong.
I'm going to get a new xml out here soon fixing the cranking enrichment
Old Jun 8, 2010 | 09:49 AM
  #505
4g94T's Avatar
Awesome!
RS, if I disable the EGR through periphery will it be okay if I leave the valve and all the hoses attached?
Old Jun 8, 2010 | 10:48 AM
  #506
RoadSpike's Avatar
Originally Posted by 4g94T
Awesome!
Should be fine it just disables the test. The activator portion is different its deactivated by setting the bit to 0. I'm pretty sure i don't have it defined for you guys.
Old Jun 8, 2010 | 08:10 PM
  #507
RoadSpike's Avatar
Here's an xml to try
File Type: zip
Old Jun 8, 2010 | 08:22 PM
  #508
03lances's Avatar
Hey RS hopefully you will know, in the tephra V7 rom I am using the accel enrichment also says (incorrect) so I cant adjust the enrichment in this rom?
Old Jun 8, 2010 | 08:41 PM
  #509
RoadSpike's Avatar
There are other tables to adjust that just don't use that one
Old Jun 8, 2010 | 09:45 PM
  #510
link62's Avatar
awesome so what changes did you make to this cause i see its slightly bigger
