Confirmed: Evo ROM Can Be Flashed to Lancer ECU
when i went out to flash the new rom with the low octane on i noticed that my cel was flashing and when i flashed the rom it stayed solid but once it was done it started flashing again it would also do this then moment i turned the key to acc it would flash and when i went to start the car it started with no problem but then died shortly after starting not being able to idle, it kept doing that so i went and put on my old tune and it started with no problem and the flashing cel was gone and it just idled so i put the new tune back on the car and took the 5 sec to crank over the the cel never came on or flashed so i went for a long drive and was able noticed the the knock was way better still some high ones but not as high as before or as frequently i was able to boost a bit and have low knock but i would lean out so need to figure that out
ok i also was wondering if it was that but now i had another problem
Log if you would the 1byte load in evoscan and I have a couple mut requests for you to log later when i can get home and look at the rom more closely.
Link here's some stuff for you to log. This can be done with either rom and all variables at once if you can. Speed of course needs you to be moving at some point
TPS:
Mut00 = 69D2
Mut01 = 69D3
Speed:
Mut02 = 6AB0
Mut03 = 6AB1
TPS Check Variable:
Mut04 = FFF1
Mut05 = FFF2
TPS:
Mut00 = 69D2
Mut01 = 69D3
Speed:
Mut02 = 6AB0
Mut03 = 6AB1
TPS Check Variable:
Mut04 = FFF1
Mut05 = FFF2
ok so log is on ur way and when i went out to the car the cel was flashing again i didnt see it till after i flashed the rom on which is the tephra one and still didnt let the car stay on so i had to flash the old one on then i put the tephra back on and it started first try but struggled to stay on but idled shortly so i went for the test log for you
also i dont have any of the tephra mods on yet
