Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old May 25, 2010 | 01:57 PM
  #376
RoadSpike's Avatar
Originally Posted by link62
ok ill give that a shot lol it sucks sitting in the car cranking the car and wondering if its gonna start
Can you find out whats the maximum throttle opening percentage for me link? I have the code set to look for RPM == 0 and TPS > 92% so if its lower than that it wont activate valet mode or alt maps.
BTW both alt maps and valet mode can not be enabled at the same time only one or the other.
Old May 25, 2010 | 02:14 PM
  #377
link62's Avatar
yea ill try and find out ill do a wot log and see what the tps max out at
Old May 25, 2010 | 02:26 PM
  #378
RoadSpike's Avatar
You could just keep the car unstarted to test it if you wanted :P
Old May 25, 2010 | 02:29 PM
  #379
link62's Avatar
fine take all the fun out of it any way i go full lean at wot right now, never could figure out why with injectors scaled perfect and the 501 maf but when i use a mix of stock maf and 501 and lower scaling seems i had no trouble boosting sigh lol
ill get u the results in a bit gotta pick my bro up
Old May 25, 2010 | 02:33 PM
  #380
RoadSpike's Avatar
Log 1Byte load and IPW when the lean event happens maybe the rom is capping the load. I don't have those turned off in your rom they are defined though.
Old May 25, 2010 | 02:44 PM
  #381
RoadSpike's Avatar
If my calcs are correct load should stop increasing around 234 without the cap removed and fuel seems to die off around 200%.
Old May 25, 2010 | 03:14 PM
  #382
link62's Avatar
ok i will cause i always had this prob with my older tunes also
Old May 25, 2010 | 05:25 PM
  #383
RoadSpike's Avatar
Ok I have a fix for the knock light ready waiting on results for the TPS bit and 1 byte
Old May 25, 2010 | 09:35 PM
  #384
link62's Avatar
log sent and the max is 95%
Old May 25, 2010 | 09:39 PM
  #385
RoadSpike's Avatar
hmm that may be the issue there too i just calculated the min which is 95%, I was off by a fraction hmmm. Odd that your car doesn't reach 100%. I'll adjust the minimum down to 80% which should solve the issue
Old May 25, 2010 | 09:46 PM
  #386
link62's Avatar
awesome and idk could be the lil throttle stoper thing behind the pedal i wonder if i removed that i could get the last 5% out lol
Old May 25, 2010 | 09:55 PM
  #387
RoadSpike's Avatar
Ah no matter if this doesn't allow the map to switch I don't know what is stopping it. I'll need to speak with tephra again if it refuses to go through may be something more like the restore sub is messing with it in some way.
Sent you an email
Old May 26, 2010 | 12:02 AM
  #388
link62's Avatar
Sent you an email
so i went a gave it a try and still nothing wont be able to try the knock light till the morning but the cel light never wanted to flash
Old May 26, 2010 | 12:07 AM
  #389
RoadSpike's Avatar
Must be some kind of bug in the tps check routine I'll have to figure it out later need to be in san fran for a couple days.
Old May 26, 2010 | 12:10 AM
  #390
03lances's Avatar
Mine maxes out at 93.33% dont know why but I do know that its the same on my scanner.
