Confirmed: Evo ROM Can Be Flashed to Lancer ECU
and no not really how would i do that?
ok so i decided to test out knock light with 3 for low and 6 for high and for it to activate at 50 load and well every time i accelerated it would start flashing non stop and continue as i kept driving and holding the pedal down it would only stop when i got to a stop or left off the throttle, i forgot to do a log while driving but im sure im not knocking all the time
The TPS activation is simple car must be on but not started and the TPS held down for the time alloted in the rom settings. The cel light should flash to tell you its activated for 10 seconds.
Sent you an email with a couple things to log too
Ok perhaps the knock sum variable is incorrect we can get to that later
ok so i couldnt get valet mode to enable, i push the throttle down and held it and never saw the cel flash i tired both at acc and at the inginition on part (car wasnt on) so i turned on and tried reving and was able to go past the 2k limit i set
also could u point out what i would need to change for the crank enrichment to help the car start better with out having to crank for 10 sec before it slowly comes to life?
and logs ur way
and logs ur way
and logs ur way
and logs ur way
