Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Just be really careful one of the ones I'm worried about is the injector scaling.
Its still basically your tuned rom but i put it back to stock as best i could.
The timing map and fuel map is from a stock evo 8 rom. Its probably too high in some areas but I don't know the 2.4L OHC turbo that well to be honest
but damn now i got a lot go through
lol cant wait to try it in the morning thanks spike you the man
so im going through the rom and was changing the maf values to the 501 and noticed that there isnt maf smoothing table like in my stock one unless its compensation but they both seem to be diff
Just renamed it compensation because it makes more sense. What it does is act as a multiplier for fuel.
ahh ok cool just making sure so im transfering the rom to my laptop and gonna go out to the car right now to try it so ill update u in a bit
ok... so good new it flashed to the ecu and then when i start it, it starts
bad news it doesnt want to stay on it seems to stumble as it revs around 1-3 k but then when it goes down the car shuts off
i messed with the injector scaling and latancies and it seem to change it from shaking the car on start up to be smooth but still dies afterwards not sure what would cause it
i messed with the injector scaling and latancies and it seem to change it from shaking the car on start up to be smooth but still dies afterwards not sure what would cause itI'll need to check on the conditions
ok so i got one log im emailing to you right now but its really short idk if it got anything cause the car dies so quick and evoscan was being retarted by connecting and disconnecting
Sent you an email link with a new rom. Hopefully *fingers crossed* this was the problem.
